Panasonic tv TC-26LX60 PICTURE PROBLEM
PROBLEM WITH THE PICTURE - turned tv on this morning and the picture is split into two screens - the first half of the picture starts on the right side of the screen, and then continues into the left side. There is black space running down the center of the screen (25% of the screen is this black space).
  • 1 more comment
  • dkdieter Jun 19, 2008
    Panasonic TH-37PX50U, lost 25% of screen, picture not displyed in lower right corner. Picture intermittently comes back. Took to repair store and they said it was DG board. Got the set home and picture display worked for four days, then problem came back for a night. Not sure what the problem is, but DG board is over $500. Could this just be loose connection?
  • Anonymous Sep 22, 2008
    We have the exact same problem "the picture is split into two screens - the first half of the picture starts on the right side of the screen, and then continues into the left side. There is black space running down the center of the screen (25% of the screen is this black space)." it occurs when we go to the HD channels than go back.
  • Anonymous Mar 23, 2014
    screen issues
    Novelist:
  • 111 Answers
If this is under warranty still, i would take it to a service center or rma it to panasonic.. if it is not under warranty, you can try the following.
1) try a different video source and verify the problem is happening on all video sources and modes.
2.a) if the problem is not happening in all modes, remove and replace the cable that is causing the issue. if this doesn't remedy the problem, the controller for that particular input is going out
2.b) if the problem is happening in all modes, you can open the case and carefully disconnect and clean (de-oxit or rid-ox) the hirose style connectors on the back of the display panel.
3) disconnect and clean all ribbon cables around the display panel
this sounds like either the connectors are not performing adequately or are loose, the top ribbon is acting up for some reason, or the graphic controller is going out.
Posted on Nov 15, 2007
  • Trinity Sabre
    Trinity Sabre Nov 20, 2007
    just following up on all of my "helpful" ratings, is there anything i can do to further help you with the problem?
Panasonic plasma tv model TC-P50x1. The bottom half of my screen has no picture. What could be the problem or how can I diagnose it?
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 30, 2016 | Panasonic Televison & Video
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
I have a Panasonic 26" LCD TV Model TC-26LX60 that no longer has any audio, the volume doesn't work nor the mute. It DOES work only sporadically and this is how I know the volume nor mute doesn't respond....
Try connecting your source device to another TV using the same cable to see if the audio works there. If it doesn't, the issue is either your source device or your cable.
Aug 07, 2013 | Panasonic Televison & Video
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
Picture will not come on but sound will.
My Panasonic TC-26LX60 Lcd tv powers on and there is sound but no picture (video)
Aug 26, 2009 | Panasonic TC-26LX60 26 in. LCD Television
2003 PT-47WXD63G...NO Sound/NO Picture
by pss your sat. to see if audio returns if so ck. settings on sat, box.
Mar 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic tc-20la2 black screen
Try calling up a Menu for Picture on the screen with your remote.  Also check that it operates the TV and not the VCR or DVD player.
Good luck.
Dec 06, 2007 | Panasonic TC-20LA2 20 in. EDTV-Ready LCD...
Panasonic trouble
Without looking at the set I would think the problem was in the optic block. An expensive repair, but, since the set is only four months old it's under warranty. Go to the service section of Panasonic.com and find an Authorized Service Center (ASC) in your area to have the set repaired. Good Luck.
Apr 20, 2007 | Panasonic TC-26LX60 26 in. LCD Television
Televison & Video Logo
1,172 people viewed this question
Top Televison & Video Experts
