Temperature on freezer shows normal temperature 4degC/ -18 degC. Real tmperature in freezer is only -8degC fridge: 6-7degC. Where to start checking for errors?
SOURCE: freezer is icing up and
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: MIELE KFN8762SDED (SS/fridge/freezer)
Have a look at page 5 (KFN8767 Miele refrigerator) it may be similar. Exact model number didnt find.
http://www.miele.co.uk/Resources/OperatingInstructions/KFN%208767%20S%20ed-2.pdf
SOURCE: Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
SOURCE: The Miele Fridge Freezer KFN8462S
Hi.
F2 indicates that there is a defrost problem. For this reason, if you turn off and defrost the fridge manually, the unit will work for a while after doing defrost.
You said that you replaced temperature sensor. What is called temperature sensor is different from the defrost thermostat, which is one of the parts involved in the fault.
If there is no defrost cycle, or if defrost is insufficient, problem is usually the defrost thermostat. The thermostat is located behind the freezer section rear wall, where the evaporator resides. To access it you need to remove frozen food and undo screws holding the back panel. The thermostat is a metal cylinder shaped object connected to two wires and clipped to the evaporator. The thermostat can be tested using a multimeter set on impedance. If reading impedance at room temp. on the thermostat contacts is infinity (circuit open),then the thermostat must be replaced. In the same way is tested the defrost heater. Check also that evaporator fan is starting.
If parts in the evaporator section are working, then the problem can be the defrost timer, which starts the defrost once every 8 hours.
Here how thermostat looks like. In same page read also the repair instructions from other users.
Regards.
Ginko.
SOURCE: My Miele fridge freezer KFN8762SDED
Hi Jean, Sorry I have no solution - but have an identical issue with my Miele fridge freezer... - In case you have managed to find a solution, I would be grateful if you could let me know what it is, to save me from running around... ?? Best wishes in any case, Guy
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
