Question about Nikon D200 Digital Camera with 18-200mm Lens
P setting on D200 Nikon
When used on P setting with a flash at night, the settings changed on my Nikon D200 from the normal 1/60 @ f7.1 at 800. The speed instead of being fixed moved depending on the ambient light in the room. Anywhere from 1/15 to 1/125.s there a way to get the camera to go back to the original 1/60?
Peter Flowers
  • 37 Answers
  1. Set the camera on manual.
  2. Set your aperture to what ever you prefer
  3. Set the speed to 1/60
  4. Adjust your speed or aperture until you like the exposure
Program mode will do what it wants...not what you want. Sometimes it makes good choices, but you have more control in M mode.
Posted on Nov 16, 2007
My sb-200 flash won't work with my d200
Go to menu then shooting and turn on ttl
Jan 17, 2012 | Nikon SB-400 Flash
Hello! When I attach the flash on my Nikon D200, it fires even while I'm focusing or just when I touch the trigger button. Any ideas? The flash is not firing like that while not on the camera.
The flash on the camera is being used to throw light for the lens to focus, unless the flash has a setting / the camera has a setting to fix this.... I would assume this as a normal behaviour.
Just to be sure that i'm thinking the same lines as you - your flashes that happen while focusing will be short bursts and when you take the final image you still have a significantly higher powered flash.
Dec 25, 2010 | Nikon D200 Body Only Digital Camera
I am using a Speedlight sb-800 on a Nikon D200. I cannot get the Zoom M function to change to Zoom. Any ideas?
Take flash out from hotshoe.
Can you set flash zoom manually?
When using Nikon Nikkor zoom & zooming, does flash zoom or hear motor sounds from head?
Jan 16, 2010 | Nikon Speedlight SB-800 TTL Flash
I want to know how to use the 952AF/Nik with the nikon d200 using multi flash units with the commander mode set to channel 1
The vivtar 952AF flash is not compatible with the D200 in commander mode. Only the Nikon SB600, SB-800, SB-900 will work with that camera wirelessly.
Oct 11, 2009 | Cameras
SB-800 Stuck in REMOTE
hers the manual on cam look under trouble shooting im still cheaking into it also
Feb 08, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Berrie Smith Camera Repair
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
what is the actual proablem?
Nov 17, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon SB600 flash behaving strangely
I have sent my SB-600 to Nikon twice in the past 6 months to resolve this problem. They have fixed it both times, but never told me what the problem was. I've had it back for exactly 1 day now, and it's started back up again already. If I receive a solution (or replacement), I'll let you know!
Nov 13, 2007 | Nikon Speedlight SB-600 TTL Flash
The symptom you describe sounds like an incorrect white-balance setting when you take the images. Digital cameras are sensitive to the quality of lighting seen when your taking pictures. First thing to try is to manually select a white balance setting and try the photos again. Try google or your manual to find instructions on how to do that. The camera can auto-adjust to some lighting situations, but fails to properly compensate in other situations resulting in the muddy or yellowed images you have seen. There is a product called "expodisc" that corrects for this white balance problem as well. Look it up. David Millier Advance Camera Repair
Feb 21, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Digital Camera with 18-200mm Lens Logo
93 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
