Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
the reason you are getting the error message is because your camera is compatible with a maximum capacity of 2gb. try to have your sd card replaced to a 2gb instead.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
vebhat, Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera... randy320sgi
You may have answered your own question. There is a good chance that your memory card has reached the end of its life. You might try reformatting the card with the computer and then do the format in the camera. This has worked for me before.
