Question about Efficient Networks SpeedStream 5200 Modem
Speedstream 5200 nat
I have an xbox 360 and I need to set the nat on my modem for xbox live conection. How do I do this on the 5200 modem? I need to change it to passive.
  • flyg Nov 19, 2007
    Ok fine after that are there any setting I would need to change to make the NAT pasive ?
  • jhgt Feb 23, 2009
    I test to get live and my mtu fails for xbox 360 how do i adjust it
  • 51 Answers
You should be able to access your modem in your web browser using as the address . if u haven't changed the password and user name they should both be admin. once in the settings change from static IP to dynamic ip this should solve your connection problems
Posted on Nov 16, 2007
X box live bad internet connection nat closed
The problem is your router, and/or your isp, the nationalities you are allowed to connect to are limited, to fix this you will need to first call your isp and ask about nat conections, and if that does not solve the problem then you will need to go into your router settings and change your nat setting, how to do this will be outlined in yoru routers manual.
Mar 01, 2011 | Buck Legendary: The Box for Xbox 360
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
I am trying to hook up xbox live for the first time. i have a isp windstream and a speedstream 5200 modem. My connection is good verified by windstream but x box cannont connect to the signal. Winstream...
  1. Step 1 Have your Xbox 360 correctly hooked up to television with HDMI or component cables. Turn your television and Xbox on. Make sure your television is on the correct input. Make sure that your WIndstream DSL Modem is on. If you have a router, make sure that it is on.
  2. Step 2 Obtain the security key for your wireless network, and write this key down. You will need this key to allow the Xbox 360 to have wireless access to the Internet. If you do not know where to find your wireless network key, you will have to access the security setup of your router. The way to do this varies by model, so check your user's manual to see how. If you don't plan on using the Xbox Wireless Adapter for your Xbox, you may skip this step.
  3. Step 3 Run a network cable (Ethernet) from your router or directly from the modem to the Xbox 360. Once you have this cable plugged in you will have to access the "My Xbox" tab on your dashboard. Go to the "System Settings" portion of the tab, usually the last portion on the right, and access network settings. For wired setups, go to the "Configure Network" option and make sure both the "IP Settings" and "DNS Settings" are set to automatic.
    For wireless setups, you will need to have the Xbox Wireless Adapter plugged into the Xbox. Under the Network Settings, enter the security key that you obtained earlier to allow access to the Internet and Xbox Live.
  4. Step 4 Create an account on Xbox Live. You will need to either have a credit card or an Xbox Live subscription card. You can purchase Xbox Live cards at your local game retailer. You will be asked to enter information and create a user name called a "Gamer Tag." This is the name that you will be known as in the x-box community hope this help you out
Jun 08, 2010 | Computers & Internet
How do I hook up to Xbox Live with VZAccess MiFi 2200
I can connect using mifi2200 and play as long as I want. However I do receive the message about NAT. Says mine is set to moderate. I have no idea how to change it to Open. I did have a regular usb modem and was connecting using it. My main problem is I cannot party up with friends on xbox live because my NAT is not OPEN. But for an answer just set up and internet connection sharing through your mifi and you will be able to connect to xbox live.
Sep 26, 2009 | Microsoft Xbox 360 Console
Xbox live says sutn bout my nat settings and i need to open some ports in order to have the best quality of xbox live...not one site actually tells me how to change them
First, try resetting your router/modem.
If that doesnt fix it you need to, from your computer, get into your settings on your router/modem. Typically from your internet browser you type in the top the modems IP address. Should be something like 192.168.1.XXX, depending on what type of modem it is will dictate what the last three are. You can find what that is by looking up your modems default IP address. If I remember right on a Linksys it is something like All of the settings can be modified from there. The Nat settings need to be set to open.
Hope that helps
Sep 21, 2009 | Microsoft Xbox 360 Console
How to change my NAT
You need to check first if your router is Xbox Live compatible (all routers will work, but only certain ones will allow an open NAT):
If your router IS on the list, make sure you have a compatible firmware version (usually the firmware version is written on the router somewhere). If you do not have the proper firmware, you will need to downgrade your firmware (reply to me for instructions on this).
If your router is not on the list, you're outta luck.
May 21, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Nat / strict
First, why are you connecting to your laptop? Second, reset your modem and router. I doubt you need to open ports that are not normally open...but if you think you need to do more, access the router and open the ports manually.
Nov 27, 2007 | Microsoft Xbox 360 Console
Need to change NAT settings for xbox live
Hey, I've had the same problem too with my NAT but it said medium instead of restricted. I havent tried this yet cause I'm at work but you restart your router by just inpluggin the power cord and waiting 20 seconds than trying again.
Hope that works!
Nov 01, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Connecting to xbox live
log into modem using in your browser and go to modem utility through browser.
then select last option on left of utility screen on left and choose reset.
this will reset modem to factory settings.
then call microsoft support there is a toll free support number in ask them to help you setup pppoe connection in the xbox. you can set the mtu setting there also to 1492 for dsl broadband and if on cable use 1500
Aug 11, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Efficient Networks SpeedStream 5200 Modem Logo
945 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
