Question about Superior Iqua BHS-801 V 2.0 Bluetooth Headset
How do i pair my iqua vogue bluetooth to my nokia phone? The bluetooth option on my phone cannot find the audio enhancement ie the iqua
What is the passcode for bluetooth on nokia phones
1234,12345, or 1111 if that doesn't work look up the manual on nokias site.
Jul 06, 2014 | Motorola Mobility RAZR V3
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
Iqua BHS-303 Bluetooth - how to reconfigure Passkey
please i forget for my passcoad my hatset si no -028165010086135 my model iqua bhs-303 please sent my mail address irfanlrazith@gmail.com
Apr 25, 2010 | Cell Phones
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
search for Bluetooth devices.
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
How to make nokia 3230 with Nokia bluetooth BH 101
you have to pair both the devices. in the bluetooth option menu switch on your phone blue tooth and move the direction pad to right side ,you will see option as pair with devices. press that. then it will ask for security code,give as 12345 and you are paired
Oct 01, 2008 | Nokia 3230 Cellular Phone
Blackberry Itune/media player/mp3 player/bluetooth operation
alright bhavin,
all you need to do is first PAIR your both the devices using bluetooth, then in black berry on music or ringtone or picture whichever you want go to.. menu-->option-->receive using bluetooth ,,,, once you allow files to be transfer from nokia you will receive in blackberry... and for sending out from black berry... select SEND USING BLUETOOTH....
i was doing the same to transfer between my nokia and blackberry phones...!!!
but for downloading this particular files, i never this so sorry about it..!!
Sep 25, 2008 | RIM BlackBerry 8700c Cellular Phone
CONNECTION TO HEADSET
It should be under Menu/Connectivity/Bluetooth/Bluetooth select ON, then, My phone's visibility select Shown to all, then, My phone's name give it a name IE. Fred (you can change the name as often as you like).
There are two tabs where you are now, select the left one, go into Options select New paired device. Your phone will search for other devices, when it finds one you can pair the two, a pin number will be asked, keep things simple choose 0000 for both devices.
Mar 11, 2008 | Nokia N73 Cellular Phone
Superior Iqua BHS-801 V 2.0 Bluetooth Headset Logo
217 people viewed this question
Top Superior Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Superior Radio Communication Expert? Answer questions, earn points and help others
