Question about HP OfficeJet 4215 All-In-One InkJet Printer
My hp officejet 6500 wireless prints red - HP OfficeJet 4215 All-In-One InkJet Printer
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
sgoswami
  • 114 Answers
SOURCE: HP officejet 6500 709n will not scan manually,
Try This :
Need to download the 64 bit OS driver from hp.com
First uninstall the complete Software from the computer
Unplug the USB cable;
Then put the CD in the computer ;
Goto My computer- Right click on Black HP logo - Click on Explore - Open UTIL (Folder)- Open CCC (Folder)- Double Click on UNINSTALLATION L3 file;
If you don't have the Cd Uninstall the software from Add and remove programs
Restart the computer ;
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-67766-1&lc=en&dlc=en&cc=us&lang=en&os=2100&product=3795406
Click on Download ;
Save to your desktop;
and then run the software;
Then while installation select the "Recommended" option and install it;
Try to scan from "HP Solution Center".. "home"
This should resolve your Issue
Regards Soumajit
Posted on Oct 23, 2009
Mhinhi
  • 10 Answers
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Posted on Mar 01, 2010
  • 18 Answers
SOURCE: how do I set up the scanner on my hp officejet
What Operating system are you running? If you goto the "control panel" and click on printers and devices, the printer should appear. Right click on it, and select start scan. Go from there.
Posted on Mar 02, 2010
Soak11
SOURCE: hp officejet 6500 wireless printer won't print
go to control panel, printers, right click on my printer icon (HP Officejet 6500 E709n), click properties, click advanced tab and check "print directly to printer"
Posted on Nov 26, 2010
Hp printer 6500 will not print red
Either you have a bad or empty ink cartridge, or a print head could be clogged. You can clean the heads with some rubbing alcohol on a q-tip. Just don't get any alcohol on rubber parts you will dry out the rubber.
Jan 18, 2013 | HP Officejet 6500 Wireless All-in-One...
Officejet 6500 wireless has stopped printing ALL color.
Send the cartridges back! HP cartridges are coded and will only work with HP printers. Hp has had problems with their coded cartridges. Especially if they were manufactured overseas. Their own product won't recognize the cartridges. It is not the printer it is the cartridges.
Feb 18, 2018 | HP Officejet 6500 Wireless All-in-One...
Hp[ officejet 6500. 1: how do i print dupex ??
I'm afraid your printer is not capable of duplexing automatically, so its a case of reinserting already printed sides the other way up.
secondly the font size is set by the software you print from.
Mar 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500 wireless printer won't print quickbooks checks
Nov 26, 2010 | HP Officejet 6500 Wireless All-in-One...
Connecting the HP OfficeJet 6500 to wired & wireless computers
Use the disk that came with the printer and install the software in both the computers based on the os installed in the individual computers, ping the ip address of the printer from both the computers, and then test for the functionality
Jul 13, 2010 | HP Officejet 6500 Wireless All-in-One...
Recently bought an HP Officejet 6500. How do I
even though my laptop has been to the hp laserJet 1010 printer, the printer doesn't print !
Oct 31, 2009 | HP Officejet 6500 Wireless All-in-One...
My hp officejet 6500 will not print pdf files . A single blank page comes out but nothing else.
have scanned records into my computer via hp officejet 6500 scanning software. when i come to print i only get the top half of the document printed on the bottom half of the page - help!!!
Oct 27, 2009 | HP Officejet 6500 Wireless All-in-One...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
729 people viewed this question
Clive
Clive
