Question about Toshiba Satellite A205-S5823 Notebook
When computer boot it go to repair screen, I pick repair , then screen display"communication with a device connect to computer usb, harddrive, cdcom... Status 0xc00000e9 Info: an unexpected I/O error has occurred It is preload Vista home system bios 1.80
  • 2,200 Answers
Try disconnecting all devices plugged into your computer and then see if it will boot. If this fails go to load last good configuration on the repair screen and see if it resolves.
If this answer resolves your problem please remember to accept and rate my answer. If not feel free to post up further information via the comment button and I will endevour to troubleshoot.
Many Thanks.
Posted on Jul 12, 2009
Toshiba satellite c55t-b5230 so now when I turn on black screen shows up saying"" reboot and select proper boot device or insert boot media in selected boot device and press a key"" can u help
its sounds like its not booting from its harddrive,it may be trying to boot from a dvd or cd device.when it ask you to select pick your harddrive,or if you have two harddrives pick your main one with your windows on it.
Apr 04, 2015 | Toshiba Computers & Internet
Acer manuals free
Hi
If it showing this screen it is looking to boot from the network .pressing the escape key usually clears this and then it should boot from your hardrive. If it is saying insert boot disk .With it been dropped the harddrive maybe faulty now . Sometimes when a computer/laptop been dropped you can hear a clonking sound which is the harddrive trying to start up and find the boot sector. If so the chance's are the harddrive is faulty and will need replacing. As the machine is booting up press the f2 key or the f12 this should a get you into whats called the bios or the screen to show what it use's to boot from . See if a friend can get you a windows cd /usb stick which is bootable and see if the machine boots up then . But I'm thinking the harddrive is probably faulty and will need replacing. Take i to your nearest computer repair place..
Dec 20, 2017 | Computers & Internet
My computer dont see my nuvi 265w
Does the unit boot to the main menu? The GPS to PC communications routine is not accessible until the unit boots to the main screen,
A common problem with these units is broken connections on the rear USB port. A bad USB port may prevent the unit from charging or communicating with the PC or both.
More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
Mar 22, 2013 | Garmin nuvi 205W GPS Receiver
POWER LIGHT TURNS ON BUT NOTHING HAPPENS SCREEN STAYS BLACK
The RAM may be faulty or just needs reseating to make proper connection.
Reseat the RAM module/s and boot up the laptop.
If the laptop still does not boot up, remove the RAM module/s and take it to your friendly computer repair shop and get them to test the RAM module/s for you. If faulty, then replace them.
Jun 13, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Hello I have a LENOVO-Y430 laptop, suddenly my laptop stopped functioning, It gets stuck in the STARTUP LENOVO SCREEN, I get two options in the bottom of the screen, press F2 for SETUP & Press F12 for...
Welcome to Fixya
Make sure first that there are no devices plug in to the usb when you boot up the computer. Check if the harddrive is being detected by the computer. Press F2 to go to BIOS menu and see if the computer can detect you harddrive. It should be under the main menu and will say below harddrive. It should give you infromation of the harddrive. If there is no information of the harddrive then the problem there is the harddrive already.
Please reply to this email for any update.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Feb 02, 2011 | Lenovo IdeaPad Y430-3231U Notebook
Cant start my laptop it reads "reboot and select proper boot device and the screen is black ?
Go in to bios by pressing del key sometimes F2 or F1 and see if your harddrive is set to 2nd highest boot priority.Set your CD/DVD drive to first. Save your settings and exit. Remove any cd's/dvd's you may have in your drive plus if you have a flash drive plugged into the usb port unplug it before starting.
If you still have this problem, your harddrive might have a problem with the booting files on it. Reinstalling or repairing windows will fix this. Put your windows disc in and boot to it.
Hopefully you wont have a problem installing or repairing windows or your harddrive could be bad. Before buying a new harddrive for it try removing it from the bay and reinstalling it, in case of a bad connection (example:harddrive wasn't fully connected.).You could go into bios and see if it shows up there.
Hope this helps ya.
Jan 10, 2011 | Computers & Internet
I have a HP Pavillion laptop. The computer is starting with the "windows error recover" running. Then once you click to repair the problems or start windows normally, the computer start to load...
The easiest thing to check is to unplug any USB drive type devices (say the MP3 player) before starting Windows and see if that helps. If not then it sounds like something on the harddrive was messed up.
You could try holding F8 at boot to get the boot menu. Select Safe Mode and see if that will boot. If it does, answer yes to the popup question and then do Start'Run and type in:
cmd
to get a command prompt. In the command prompt type:
chkdsk c: /f
It should say that it can't check the drive right now (since Windows is running off that drive) and ask if you want to check it at boot. Answer with a y. Then reboot, let it try to startup normally, and chkdsk should run and check the drive for errors.
If that doesn't work (can't boot safe mode) and If you've got a Windows CD, (XP SP2 version disc may be needed if you have really large harddrives, doesn't have to be the disc used to install Windows on that computer) you could try booting it and go into the Recovery Console. (Basically a dos prompt type thing.)
Then type:
chkdsk c: /p
It should check the harddrive for errors and if it finds some will try and fix them. If when it's done it says it found and fixed one or more errors, then I'd do it again and see if it says it found one or more errors. (If it doesn't say that it found errors the second time then, hopefully, that means it fixed the errors it previously found. If it keeps finding errors every time you run it then that may indicate that the drive is failing.) In any case, running chkdsk once as above may help you get into Windows. (I'd still have it do chkdsk c: /f on reboot as above after booting Windows, just to be on the safe side.) You will need to have set a password for the Administrator account to do the Recovery Console though. (Administrator account is accessible when booting in Safe Mode.)
If you can get Windows booting (by any method) one thing you can do that might help prevent this from happening in the future is to disable disc caching for the MP3 player.
Plug the device in, right click the "Safely Remove Hardware" icon and choose "Safely Remove Hardware."
Check the Display Device Components box if it's not checked.
Find the MP3 player in the list (likely under USB Mass Storage Devices) and click it.
Then click the Properties button. On the properties window click Policies and set it to "Optimize for Quick Removal" and click OK.
From now on (at least on that computer) you should be able to remove the MP3 player without using the Safely Remove Hardware tray icon, as long the computer's not actually accessing files on the drive.
Nov 13, 2010 | HP Computers & Internet
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
Operation of computer while connected to F380 .
Hai
I understand that your Isue is "After installing the HP All-in-One software, the computer stops responding during start up when the All-in-One is connected and turned on. The computer will start correctly if the All-in-One is not connected or is turned off."
SOLUTION:
This problem can be resolved by changing the "USB Emulation" in the Computer BIOS settings.
If you are using a DELL Computer just follow my instruction below.
Caution:
If you are using a USB keyboard, do not disable “USB Emulation”, “USB Keyboard Support”, or “USB Legacy Support”. If the settings must be disabled, use a PS/2 keyboard
Changing the BIOS on a Dell Dimension computer
Follow the steps below to turn off the ability to boot from USB devices but still support a USB keyboard while starting. Contact Dell for assistance if necessary.
  1. Shut down the computer.
  2. Unplug all USB devices other than a keyboard.
  3. Start the computer. When the Dell logo displays, press the F2 key to enter the System Setup (BIOS) program. If the Windows screen displays, wait for the computer to finish starting up, shut it down, and then try again.
  4. Press the Down Arrow key to highlight Integrated Devices (Legacy Select Options).
  5. Press the Enter key.
  6. Press the Down Arrow key to highlight USB Emulation .
  7. Press the Space Bar until the “ No BOOT ” option displays.
  8. Press the Esc key twice to go to the Exit menu.
  9. Plug the USB devices back in.
  10. Ensure that “ Save Changes and Exit ” is highlighted, and press the Enter key. Contact Dell for assistance if the problem still exists
Changing the BIOS on a Dell Laptop PC.
  1. Shut down the portable.
  2. Unplug all USB devices including USB keyboards.
  3. Start the laptop. When the Dell logo displays, press the F2 key to enter the System Setup (BIOS) program. If the Windows screen displays, wait for the computer to finish starting up, shut it down, and then try again.
  4. Press and hold the ALT key while tapping the P key until a screen displays that includes the words “ USB Emulation ”.
  5. Press the Down Arrow key to highlight “USB Emulation”.
  6. Press the Right Arrow key until the “Disabled” option displays.
  7. Press the Esc key once to go to the Exit menu.
  8. Plug the USB devices back in.
  9. Ensure that “Save Changes and Exit” is highlighted, and press the Enter key. Contact Dell for assistance if the problem still exists
Change the BIOS on computers from manufacturers other than Dell If you do not have a Dell computer, contact the computer manufacturer for assistance. If the manufacturer does not know how to disable starting from USB devices, they may be able to change the order (boot order) of the disks the BIOS uses to start the computer. Move the bootable USB devices selection lower on the list than the computer hard disk drive. If you have any further queries or if the problem still persists, reply me. Thanks Riz (jack_36623@yahoo.com)
May 20, 2008 | HP DeskJet F380 All-In-One Printer
Unrecognizable USB External Harddrive
dear jpaws check your computers device manager. ithink you need drivers please install a driver.
Feb 25, 2008 | Computers & Internet
Toshiba Satellite A205-S5823 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
