Question about RCA HD56W58 56" TV
HD61W66YX60 I HAVE A 61" HDTV model # HD61W66YX60 there is currently no picture but a few bowed lines going across the top of screen all the way across in the top six inches of screen the lines are thin and different colors. The sound works perfect- This just happened today and TV has worked perfectly in the past. Purchased TV 16 months ago. TV is still under warrenty but would like to know what problem is. Thanks in advance.
  • Anonymous Feb 17, 2008
    still have picture but picture is bowed and has some double exposure in the colors
  • Trixy434 Feb 20, 2008
    Our picture is actually bowed and the convergence function is no longer an option, it has just completely disappeared. Our TV RCA HD61W66 is also under two years old and we have a warranty but like you I just want to know what caused this (still waiting on service Tech).
  • 60 Answers
This is a convergence issue. it is caused by one of three things
1. a bad convergence board
2. a bad fuse feeding the convergence circut
3. a bad relay feeding the convergence circut
whatever the one it is they all have the same result, an inoperative convergence curcut. needs service .
if it is still under warranty, great. If not the parts can cost up to $300 and labor can be the same
Posted on Nov 22, 2008
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
May 29, 2016 | Quasar Televison & Video
Picture problems
Is it one color that has moved? Sounds like a convergence problem. Find a channel with a fixed picture, or if you have digital cable or satellite pull up a guide, something with a straight line across the screen. You will likely see one of the colors is bowed or or shifted. You may be able to adjust that with your remote under the "convergence" adjustments in the menu. If it will not adjust it will need work done to the convergence circuit. Not a DIY project.
May 24, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
Picture problems
check for cold solder joints around the flyback transformer and a open pico type fuse very close to it. they are rectangle in shape and ususually the one in the middle of the three is the culprit. The problem is in the pincushion circuit
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Goofy intermitent picture (bows with wiggly fibers across screen)
Convergence amps are going bad replace these and you will fix your intermittent problem.
josh
Mar 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
No picture have sound
sounds like your IC's took a dive again. Did you change them or a shop? You have to also make sure that when you change the IC's that you put plenty of heat sink compound on the back of the IC's and do not use the cheapy IC's that you can get for 20 bucks or less as I have found they do not last. This convergence board should be available as a complete board. Good Luck
Mar 29, 2007 | Zenith IQZ60Z97D 60 in. Rear Projection...
Picture Distortion
you have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Mar 30, 2006 | Sony KP-53HS30 53" Rear Projection...
RCA HD56W58 56" TV Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
