Question about Fitness Quest Eclipse 1100 Hr/A Elliptical
Edge 491 exercise bike monitor panel dead
Just purchased edge 491 exercise bike. Monitor panel dead, replaced batteries, no change Have no manual, schematic, or info on source for replacement parts.
Http://www.academy.com/images/pdf/Fitness_Quest/Edge_Recumbent_Bike_491r.pdf
Mine went dead last Spring. I ordered a replacement part from Fitness Quest. I think the link is above. Actually, while I was waiting for the part, I reconnected all the wires on the whole bike and the panel worked. So I actually have an extra new working panel if Fitness Quest doesn't have the part for some reason and u want mine. Double check ALL the connections of the wires first. They come loose easily.
Nancy
Posted on Aug 10, 2009
  • 2 more comments
  • nthackaber Apr 04, 2010
    monitor part no longer available!
  •  Mark a parker
    Mark a parker Nov 19, 2012
    I now it's been 3years but do you still have the control panel?
  • David Russell Jan 26, 2013
    I would be interested if you still have the control panel
    I would be interested if you still have a control panel
    New Friend:
My bike kept giving me a "low battery" message, so I wired in one more c-cell battry (for a total of five batteries instead of four), and voila! It works fine now. I was worried the extra voltage might harm the mechanism or the computer but it works fine.
Posted on Feb 10, 2015
How importance of Heart-Rate Monitor on a spin bike?
The high-quality exercise bikes are best for having a chest strap since they do not hinder the movement while exercising. It is inconvenient when the users will touch the contact monitor; it will start gauging their heart rate. Using a standalone heart-rate monitor will be handy in this point of view.Click the link for more info Best Exercise Bike
Apr 16, 2018 | Exercise & Fitness
How do I replace the batteries in the BodyChamp BRB5200 Monitor?
Download a free manual that will walk you through on how to replace the batteries for your BodyChamp BRB5200. Here's the link http://bodyflexsports.com/gama/wp-content/uploads/2012/10/BRB5200%20Manual%2004062012.pdf
Jun 28, 2015 | Body Champ Magnetic Recumbent Exercise...
Exercise bike instruction manual
WARNING Do not attempt to open the back cover of the Monitor console. This is not a battery storage area; this Computer is powered by an AC Adapter. This bike is to be used only indoors and in a dry location. Do not plug the AC Adapter into the wall until the electronics monitor is completely assembled.
Jul 16, 2014 | Fitness Quest Edge 482U Upright Exercise...
Is there a heart rate monitor on exercise bikes?
Most of the exercise bikes come in three flavors. Either they have no heart rate monitor at all or a pulse grip heart rate on the mid-level bikes or a wireless heart rate on the top exercise bikes.
Aug 09, 2012 | Exercise & Fitness
I got onthe bike today and it had quit working --the moniter comes on but none of the control buttons do anything it just flashes the manual contol on the left side of the screen -- it had been working...
I have the same problem and called fitnessquest. They said the monitor is probably bad and they don't have any in stock because it is being discontinued. The customer service person told me to buy a used bike somewhere and use the monitor from it. Not alot of help.
Apr 20, 2011 | Fitness Quest Edge 482U Upright Exercise...
My "Edge 491r" recumbant bike
Same as above, have an Edge 491 with E1 and need to fix it
Jan 04, 2011 | Fitness Quest Eclipse 1100 Hr/A Elliptical
I have an Edge 491 Exercise bike and the control
Take a look at the battery compartment under the panel (left looking up). I had a similar problem and had just fixed it. Hopefully you can get the same results.
If the strip of metal with the spring is corroded, take the batteries out, and carefully remove the metal strip. I used metal duct tape and wrapped the piece of metal with the tape. Carefully put a slight bend in the middle of the strip and reinsert the strip. If the batteries do not connect up, bend the piece a bit more or add more of the metal duct tape. After doing this, the panel came back to life. If this is not your problem, then my apologies. If it is, then good luck.
Feb 02, 2010 | Fitness Quest Cycling
Tension
The new and improved exercise bikes have what is called magnetic resistance. This is where your resitance is created by a magnet and some sort of power source such as batteries or your bike being plugged into a wall outlet. If you are using batteries replace them. I found that with my elyptical exerciser new batteries made a world of difference in the resistance settings. Make sure the batteries are strong ones. If changing the batteries doesn't help then there may be another problem. This could be the computer or a magnetic part. These parts are usually replaceable through the manufacturer. Just check your user manual and I am sure you can get it replaced. I hope this has been helpful.
Mar 16, 2009 | Cycling
The monitor on the EDGE 482U Upright Bike does not work. The only buttons that work are enter and recovery.
I contacted their customer support after putting the bike together two times. There was no indication in the manual that there was a motor inside the base. Customer support offered to replace the motor. I am returning it to the store for a refund.
Dec 28, 2008 | Fitness Quest Edge 482U Upright Exercise...
Fitness Quest Eclipse 1100 Hr/A Elliptical Logo
5,486 people viewed this question
Top Fitness Quest Sport & Outdoor - Others Experts
Joseph Mueller
Joseph Mueller
Dave Callender
Dave Callender
Rigger
Are you a Fitness Quest Sport and Outdoor - Other Expert? Answer questions, earn points and help others
