Hello, usually turning off the breaker for at least 1 minute or more will reset the board. If you are getting a set of lights blinking, that is an indication of a problem--normally, dishwashers will blink certain lights in a pattern(digital error code) and depending on which lights and how many blinks, you have to decipher the type of code from the service manual.
SOURCE: Bosch Dishwasher, model SGS6312GB/07. The water
press cancel/drain sequence to get water out-check owners manual.
2 possible solutions to your problem discussed here:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
problem may be a burnt out solder connection on circuit board
call bosch to see if it recall issue
