Question about Sony Cyber-Shot DSC-P52 Digital Camera
Camera will not take photos
When powered on to take pictures, my camera give a message with a beeping sound saying to "Turn the power off and on again"?
What can I do to be able to take photos.
  • kitte730 Nov 26, 2007
    My camera clicks loudly and says turn camera off and back on...i tried taking the bateries out and tried it again but it doesnt work....PLEASE HELP..
  • quarteraspy Dec 12, 2007
    The first thing the camera started doing was saying that there was no memory stick I know that was an era i have three memory sticks and I tried all of them and it said the same thing. Then today its saying turn off and back on and its making a funny noise and I noticed the shutter window is not opening.
Its hard but must of all problems people have with those cameras its cuz they've dropped it or hadle them in rude ways(Now if u want to be in denial be my guest). The Problems have to do with the "Motherboard(a green-square-plastic-chipset inside the camera) Connectors"(the connectors to the motherboard) i "DO NOT" Recomend you to open it but the problem lais there some of the connectors come off with the impact of a fall or mistreatment and some one with eye precision has to take a look at it cuz the parst are as tiny as they get and to fix it it takes about an hour of patience.
Posted on Dec 10, 2007
    Genius:
  • 2,985 Answers
Remove the battery and keave fir a minute
Reinsert and try once more.
It the problem persists then contact Sony Customer support for further advice.
Posted on Nov 15, 2007
When I turn the camera on it says access , the lens goes in and out then I get a beep and message reads turn the power off and on again. I've done this over and over again and it still won't work. ...
One thing to test before going to repair, make sure you are using a fully charged and correct battery for your camera.
If so, the camera will need repair. This is a common problem and can be fixed. Teleplan Camera Repair does a great job and their blog is also very informative.
Repair: http://www.teleplancamerarepair.com/Sony_Cyber-shot_DSC-W30
Aug 04, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
When I turn my camera on, the screen remains black and says turn power off and on. Upon doing so, when i turn it on again, it begins beeping and says turn power off and on. But if I go to the view pictures...
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Jan 30, 2010 | Sony Cyber-shot DSC-M2 Digital Camera
When i turn the camera on it says format error and i cant take any pictures
Please take out memory stick from camera and power up camera and check still gives format error?
If no further error then put memory stick back in camera and press Menu >> Format >> OK to format memory stick. That will delete all data on memory stick and refresh it for new photos.
May 17, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
CANNON A520 POWER SHOT DIGITAL CAMERA
Tab on the camera. E18 is a stuck lens. This is common on this camera. I'm not saying this will fix it, but don't break it.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Jan 08, 2007 | Samsung Digimax S500 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
29 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
