Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Mower shuts off while mowing grass - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
    Problem Solver:
  • 4 Answers
Yes, I recommend that you stay on the mower to keep it from shutting off.
Posted on Aug 03, 2009
  • 41 Answers
Check the switch that is located under your seat. If you are not on the mower while it is running the switch tells the mower to shut off. hope this helps
Posted on Jul 12, 2009
Mulch insert frequently gets clogged and mower stops running. I have to turn over the mower and use a stick or similar garden tool to clear out grass from around the mulch insert once EVERY pass.
Dear Sandi,
If I read your missive correctly, I believe your mower is too small for this task.
It would appear to me you could do one of 2 things.
1) mow it more frequently , before the grass grows so tall, ( like maybe 2-3 times a week,) or get a bigger and stronger mower.
Remember too, electric mowers are not usually very strong, but gasoline engine mowers , some are so strong they can mow a forest!
.God bless your efforts.
Jun 29, 2018 | Black & Decker Cmm1200 24v 19" Cordless...
Tip
Personal Safety
Be sure to take the right safety precautions before you mow.
  • Never attempt to lift or repair mower with engine running.
  • When mowing with a walk-behind mower, wear heavy-duty shoes with non-slip soles and long pants to protect your legs.
  • Always wear eye protection when operating a mower.
  • Don't mow a wet lawn or late in the day when the light is dim.
  • Never let the starter robe snap back when starting mower.
  • Always mow up and down an incline with a traditional (i.e. unit with steering wheel) riding mower.
  • Always mow across an incline with a residential walk-behind mower.
  • Never adjust mower height, clean grass chute, or remove grass catcher with engine running.
  • Always stay clear of hot engine. Mufflers can reach up to 1,200 F (648 C
on Apr 02, 2011 | Garden
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
How do i restart my cubcadet model cc46es after it stalled because of grass
disengage pto start up move to alredy mowed area shut off and clean grass from under deck restart it turn on pto cut grass
Jul 11, 2014 | Cub Cadet Garden
Toro 20022 grass buildup
at tractor supply has a paint called slip
May 25, 2012 | Toro Power Lawn Mower
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Deck will not shed the grass . the grass has to be cleaned after each mowing, lawn is not mowed when wet,
The only way to shred the grass while mowing is to have a pair of mulching blades on your mower, they work, but they wear out fast. They do in Florida anyway with all the sand. And don't for the grass to look a hayfield to mow it. You have to keep at it. Hope this helps.
Apr 04, 2010 | Husqvarna Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
326 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
john h
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
