Question about D-Link DFE-530TX+ Fast Ethernet PCI Network Adapter
Just installed a D-Link DFE 530TX network adadpter into Dell Dimension 5000 desk top. Runnng Windows XP SP3. BT Home Hub 2.0 router. Even though broadband connection is fine to the router. The network adapter on the desk top which is connected to router via ethernet cable, has limited on no internet connection. So am unable to connect to internet. Have run the BT home hub diagnostics but cannot fix the problem. Any help greatfully recieved. Cheers
  • 39 Answers
Sounds like an IP address problem. Your IP address on both the NIC card (DFE 530) and the router have to be in the same address range. You can do this 2 ways. 1... Have your router hand out addresses automatically. Make sure DHCP is enabled and that you have at least one address available for it to give out. ie. 192.168.0.2 through 192.168.0.3. The first three number must be the same as the router. The other option is to manually set your IP address on your nic card to match the router. If the router is lets say 192.168.0.1 then you can assign 192.23.34.2 to your computer NIC. If you haven't been able to access your router then check your router manual to find out the default IP address and use the same number for your NIC changing only the last number. The largest number you can use is 255. Hope this helps.
Posted on Jul 12, 2009
Bt Homehub 3 + dell 1450 wireless router asking for network key
if the routor is wireless then the key is on the bottom or side of router. the ip address should be on it too and pass key to change the settings on the routher
Jul 01, 2017 | Dell 1450 (D1450U) Wireless Adapter
NOT GETTING DLINK DFE 50 TX DRIVER
D-Link's support site shows that this product was discontinued in 2001. The operating systems supported by the driver only show up to Windows XP and not Vista or Windows 7. Windows XP has the driver in the operating system so you should be able to use the Add/Remove hardware wizard to install the driver within Windows or try from the CD that came with the card. If you are using a later operating system, there is a good possibility that the product is not supported.
Cheers!
Nov 19, 2010 | D-Link DFE-530TX Network Adapter
I closed my business last month and my desk top dell dimension was networked with microsoft xp pro and i want to take the hard drive from that somputer and install it in my home computer which is a stand...
HI,
When you remove the harddrive from a computer and plug it into a different machine though of the same model.It would not boot, because the operating system product key is unique to the machine. If you want to use this particular hdd in your home system, make it a secondary harddrive or reload windows on the harddrive again. But doing so , you would remove everything from the harddrive.
Thanks for using Fixya
Proton
Nov 07, 2009 | Dell Dimension 4600 PC Desktop
I LOST MY DRIVER CD.WHERE CAN I GET FREE INSTALLER DRIVER?
though i need to know the os u r using..
considering that u r using win xp or vista..
howevr, along wid the company, there will b a list of such site n driverdownload links if u search by the model name on a search engine likegoogle..
download them onto a location; if the driver is in a zipformat, unzip it,if itz in .exe form, just run it; if done manually it'llask for the correct driver and location; relocate the path and a.inffile (wat it'll ask for)..
try downloading..
http://www.driverskit.com/freedownload/Net_Card/D-Link/DFE-530TX/17529.html
but always better to consult ur system admin/vendor....
Nov 06, 2009 | D-Link DFE-530TX+ Network Adapter
D Link DFE 538TX (DL10038D)
Download the drivers here:
http://www.cc.uom.gr/pub/DRIVERS/NETWORK/D-LINK/DFE-530TX/
Oct 31, 2008 | Computers & Internet
Running at 10 mbps
There's possibility that the network (router/modem/switch) you're trying to connect has limit to up to 10 Mbps only. Or it can be that the current LinkSpeed of the Ethernet adapter might be forced to 10 Mbps. Do the following to check this setting:
  1. Go to Control Panel> Network Connections.
  2. On Network Connections, look for Local Area Connection (for the D-Link adapter). Right click it then go to Properties.
  3. On Properties window, click Configure button.
  4. On the next window, go to Advanced tab.
  5. Look for Media Type, Connection Type, or LinkSpeed and Duplex Mode.
If the value is set to Auto Negotiation/ Auto/ AutoSense, try to force it to 100 Mbps.
Jul 22, 2008 | D-Link DFE-530TX Network Adapter
D-Link DFE-530TX+ Fast Ethernet PCI Network Adapter Logo
966 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
