Question about Homelite Mighty Lite Lawn Trimmer
Won't maintain speed. shuts off. - Homelite Mighty Lite Lawn Trimmer
Why does my 2003 pontiac grand prix maintain speed on flat surface when cruise is not turned on?
Sounds dangerous and hard on breaks. I\'d catty with the throstle linkage under the hood. It should twist open with a bit of pressure, than snap shut when you let go. Yours won\'t. The return spring is worn, stretched out, or most likely gone missing or fell out. Find it and hook it up. Or any spring with the power to pull it back to a closed position. Must be hard to restart the car after it\'s warmed up too.
Jul 12, 2014 | 2003 Pontiac Grand Prix
Rpms fluctuating in all gears
check fuel system, fuel filter maybe need replace or spark plug
Jul 31, 2013 | Honda Accord Cars & Trucks
Precor c965i won't maintain speed the more weight on it
weel you must read the specification of your model, what is the maximun weight that is acceptable. However you must LUBE the deck belt with silicones or wax , read your owner manual for this, and execute inmediately.
God bless you
May 29, 2013 | Exercise & Fitness
1996 eldorado etc car won't go over 90mph. Dash
Based on the photo, I would say the air suspension can not maintain the car at the height it is supposed to be. As long as the height is not right, the speed is limited for safety. The computer does not know you changed the wheels.
Jul 26, 2012 | 1996 Ford Explorer
2001 Jeep Cherokee Country 4.0 Litre Straight 6 , won't idle when warm
IAC (idle air control) can not maintain idle target speed4_14_2012_12_11_46_am.jpg
Apr 11, 2012 | Jeep Cherokee Cars & Trucks
My Dyson DC16 usually shuts down after about 5 to 10 seconds. However, occasionally it will run for 45 seconds to 1 minute before shutting down. It is left on charge permanently. I have checked the...
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Mar 23, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My Nextbook shut down and won't come back on
If the temperature is hot in your place then the PC Laptop may shut down due to overheated system.The machine automatically shuts down to prevent any internal damage. However in some cases you can prevent the shut down if you can control the speed of the CPU fan which can be done by the following software called "Speed Fan 4.42".
Download it from here.
http://www.almico.com/sfdownload.php
If the weather is not hot around you and the system still shuts down then at least cleaning service is required from a good repair shop or a tech. There must be a lot of dust and the ventilation system might be choking with dust and unwanted atmospheric objects so proper air flow can be maintained in the machine.
Good Luck!
Jan 14, 2011 | Computers & Internet
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Homelite Mighty Lite Lawn Trimmer  Logo
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
