SOURCE: Remote Control codes -CL015 Zenith
sylvania tv codes are what you need try these 0062 0004 0009 0135 0189 0183 1141 0227 0456 0458 0008 0068 0075 0141 0161
SOURCE: zenith remote will not work tv, need code
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
SOURCE: Philips Universal Remote #CL034- Need tv codes.
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
let me know if this helps
SOURCE: zenith universal remote codes
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=zenith&dv=universalremote&md=zn501s&kw=&st=&ar=&dt=&so=&pg=2&file=others/zenith/zn501s-manual.zip
Unfortunately, there is no code sheet included in this user guide. However, Code Search is covered on page 10.
Testimonial: "thanks, took 2 minutes and i was back in action"
