Question about Kenmore 63942 Dryer
TAKES AT LEAST 180 MIN. TO DRY LOADS, 90 SERIES.
    President:
  • 1,273 Answers
It sounds like either of several things. Check the air discharge from the dryer where it exits your house, and be sure thet it is blowing strong. If it is not, you may have a partially plugged vent circuit. Unplug the dryer. Make sure that your vent hose and outlet ducting are clear of debris. Take the duct outside and clear it out. Check the inside rear of the dryer, where the duct connects, for debris, lint, etc..
If you have a strong air flow, you may have durned out heating elements. Again, with the dryer unplugged, gain access to the element leads and test for continuity, if you have a test meter and know how to use it. Replace any broken elements. Parts are readily available from most any appliance parts supply house.
Best regards,
--W/D--
Posted on Jul 12, 2009
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
Takes long to dry clothes
on your side, it is better you don't touch anything internal in the dryer as you can hurt yourself and spoil the device even more. have a professional take a look at it before you use it any further.
Jun 11, 2010 | Kenmore 62802 Electric Dryer
Does not dry clothes takes 180 min how long can
idealy most manufactures reccommend 8 ft
with each elbow equal 3' there are variations of that
but its a good rule of thumb.
a two hour dry usually means some loss of circulation with in the system
good call
Oct 13, 2009 | Dryers
Kenmore dryer 90 series, heats a little, but doesn't get hot and takes 3 to 4 1/2 hrs to dry a med. size load.
Check vent path from lint filter all the way to the exhaust vent to make sure it is clear. If the dryer has a wet/dry sensor it could be malfunctioning. Try a manual cycle to see if the problem occurs then.
Jul 18, 2009 | Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
Wont dry very fast
Nope change the control thermostat mounted beside the skinny white fuse on the blower housing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 30, 2009 | Kenmore 62602 Electric Dryer
Dryer is not drying correctly
ck vent system to outside ck for crimped vent hose on back or plugged vent to outside ..if burner ignites but fails or is slow to reignite suspect the coils on burner (the 2 black things with wires attached)
Aug 20, 2008 | Estate TGDS840JQ Gas Dryer
Kenmore 63942 Dryer Logo
98 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
