Question about Brother GX-6750 Typewriter
How to correct Daisy Wheel print malfunction?
SOURCE:
  • 4 Answers
SOURCE: My GX-6750
The print whell may be rubbing on something....exp ribbon....check and make sure there is nothing blocking the free movement of the wheel.
Posted on May 01, 2008
  • 331 Answers
SOURCE: Brother GX-6750 Daisy Wheel
Install wheel, turn machine on and off this resets the printer and home timing. If it still does not correctly, adjustments needed..
Posted on Jun 12, 2008
JUSTOLDJIM
  • 481 Answers
SOURCE: No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Posted on Nov 06, 2008
bjwanddave
  • 3 Answers
SOURCE: DAISY WHEEL
typing "code" and "reset" sets it right to type
Posted on Aug 05, 2009
FJA Products
  • 30 Answers
SOURCE: Changed Daisy Wheel and it's still not typing the correct letters
You can see the info on replaceing the daisy wheel here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_GX6750_EN_214.PDF
If yo need more assistance- you can give us a call or send an email.
Take care and good luck
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082
Posted on Sep 16, 2009
How do I insert the daisy wheel on my Swintec 2416 DM typewriter?
Remove the ribbon, then remove the daisywheel, reinsert daisywheel, replace ribbon and it should work.
Jul 01, 2014 | Swintec Office Equipment & Supplies
How do i set a new daisy wheel for the ML 100
1. Open the top cover.
2. Pull the lever towards you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear' on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its' original position to lock the cassette daisy wheel in place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press [CODE]+[RESET] to move the carrier to the previous position.
(make sure the daisy wheel cassette is not inserted backwards. The "ear" should always be on the upper right.
improper insertion of the daisy wheel may cause malfunction and incorrect printing.
It is not necessary to remove the cassette ribbon when replacing the daisy wheel.
Please check the shape of your daisy wheel cassette before replacing the daisy wheel. The daisy wheel cassette type "B" cannot be used with this machine.)
Dec 22, 2010 | Brother ML-100 Typewriter
My typewriter does not print. I do not have a manual or instructions for this typewriter. Is there a code I will need to insert in order for it to print...delayed or otherwise? Thank you!
Check that the daisy wheel is properly installed and if the ribbon has been used up. Try pressing and holding CODE and then press Reset. (This needs to be done after the daisy wheel, correction tape or ribbon is replaced.)
The daisy wheel has a protruding ear that should be on the top right. To remove, open the cover, pull the lever towards you and lift the wheel by that ear. To reinsert, insert the wheel in the slot and press down gently. Then slide the lever forward to lock the wheel in place. Then close the cover and reset the carrier (CODE+Reset). Make sure that the ear is to the top right when you reinstall the daisy wheel.
The amount of ribbon left can be determined by looking through the viewing hole on the right hand side of the cassette when the cover is open.
The manual is available here: http://www.brother-usa.com/manuals/default.aspx?PGID=10&R3ModelID=ML100 as a PDF.
I hope this helps.
Nov 09, 2010 | Brother ML-100 Typewriter
My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
Oct 26, 2009 | Brother ML-100 Typewriter
I have a Brother WP-2000 word processor and when I changed the Daisy Wheel the letter typed is not printed and another letter or symbol is printed. How do I align the daisy wheel so this does not happen
Turn the typewriter off, remove the daisy wheel.
USUALLY there is a small rectangular slot in the daisy wheel that points up.
Insert wheel and turn on.
Make sure your spacing is NOT set to PROPORTIOAL SPACING
Nov 20, 2008 | Brother Office Equipment & Supplies
Wrong letters typing
it sounds like you were using a non-brother correction tape,one that was too sticky and consequently too "slow" and during the correction sequence the fingers of the daisy-wheel got entangled with the tape. Make sure that the correction tape is of a "non-sticky" nature and then take off the correction and printing tapes. That way you will see better how the daisy-wheel is fitted . I will assume that you have an instruction book to show how this is done. before fitting the daisy wheel examine the fingers to see that none are bent or crossed over each other. If this is the case it is better to buy another one. bring your typewriter to the shop if this is the case and they will possibly re-fit the wheel for you. good luck.....
Mar 19, 2008 | Brother ML-300 Typewriter
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Brother GX-6750 Typewriter Logo
364 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
