Question about Kodak EASYSHARE Z1285 Digital Camera
My camera sometimes won't turn on. I'll be using
My camera sometimes won't turn on. I'll be using it and it just stops working and the lense gets stuck out. When I try and turn it back on the blue light will flash but it won't come on. Eventually it will work again. The camera has never been dropped or exposed to anything.
    President:
  • 2,761 Answers
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
On our panasonic DMC - SZ6, the lense cover won't open when turned on
Lens covers are delicate things. A bit of dust or dirt inside and the the springs can't do their job. When cleaning doesn't work, to repair this I remove the lens cover and shorten the springs by cutting off a bit and then reattaching them. A small bit of mollyd to lubricate helps too. never use oil or silicone.
Oct 31, 2017 | Panasonic Lumix DMC-TZ3 Digital Camera
Won't stay on
Sound like a stuck lens problem; check here about fixing-lens-error-on-digital-camera.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 03, 2012 | Fuji FinePix A330 Digital Camera
Sigma lens won't turn past 1.3
Make sure you are zoomed out all the way, many lenses when zoomed in will only let you stop the aperture down so far at certain focal zoom lengths.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Jun 01, 2012 | Sigma 30mm f14 EX DC HSM for Minolta
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
DOES SIGMA 70-210MM UC MF FIT AND USABLE ON NIKON D5000
Sigma makes lenses for a variety of cameras. If the lens has Nikon mount then it will fit onto the D5000. However, it's a manual focus lens so naturally you won't get autofocus. The lens also lacks the electronics to communicate with the camera, so you will get no help from the camera's exposure meter and you'll have to shoot in Manual exposure mode.
Jul 03, 2011 | Cameras
Hi I cannot get my F80 to autofocus. I have tried all my lenses on my Brothers F80 and they all work fine on his camera. I only bought the camera second hand a few days ago and i'm 99% sure when the...
If the gears are stripped, it will require an experienced tech to repair.
That being said, there should be a small switch near the lens mount to switch between auto and manual focus mode's, be sure that that switch is pointing to A. When set to M, the little screw recesses into the mount so it doesn't try to engage, when set to A, it'll extend very slightly.
Also, Nikon has manufactured two types of AF lenses - with the motor in the body and with the motor in the lens, as with most newer lenses. Your camera should have a small screw on the lens mount that drives the focus motor between the lens and the camera, but I'm not 100% certain on that. Your camera can focus lenses with and without this type of coupling. BUT, if that screw/motor in the body is not functioning, you'll only be able to use lenses which contain the focus motor inside them, or manual focus lenses (you can manually focus AF lenses too).
May 19, 2011 | Nikon F80 35mm SLR Camera
F error code
Check the contacts on the camera and the lense.
This error means there is a communication error with the lense or it thinks that the lense is stopped down. Since its a G lense it cant be stopped down manually its gotta be some sort of communication issue. The electrical contact pins are springy and stick so they don't fully extend sometimes. This will improve with wear as the plastic channel is a bit too small and is holding the pin in the retracted position - repeated use will get the channel to get larger. I fixed mine by working the pins in and out manually until they all reliably sprung into position. Removing the lens a few times and fiddling with the contacts seems to have solved the problem..You can check by moving the lens when it is mounted to see if you can replicate the error.
Dec 21, 2009 | Nikon D90 Digital Camera with 18-105mm...
Lense error
send it in for repair. their is no easy fix for this sorry. www.digitalcamrepair.com can help.
Jul 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
102 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
