you need to replace your power supply! asap!!! check the voltage coming from the ac adapter to verify the correct voltage!! please vote and rate this post!!! thanks
The correct number is MC306Vome-107FP mitsubishi part # 275P363030. I am not positive that you can get that IC it is considerd obselete you normally have to replace the signal board. However I doubt that is your problem. Have you checked the chassis for corrosion due to coolant leaks?and or bad capacitors? That chassis is prone to crt coolant leaks causing PB corrosion and solder deterioration. The signal board is pricey, If you can locate one.
