Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer LEC8858EQ2
My dryer turns on but as soon as it heats up it will go off again. After it cools down it will turn on again by itself, but when it heats up it will turn off again. I believe that it is the heating element, could it be something else?
  • eagles68a Sep 16, 2008
    I have Whirlpool Dryer (LEC8858EQ2) that dies not start.
  • bretto962 Nov 29, 2008
    Whirlpool LER5636JQ0 turns off after 5 minutes. Exhaust is clear. Heating element is working, but dryer surface not too hot. First problem in 7 years of ownership.
One of 2 things, over temp protection activating due to insufficient ventillation or motor is defective and heating up excessively.normally if both drum support wheels are worn or defective,plus if veld strip on drum is worn, motor will overwork and fail.
Posted on Nov 16, 2007
Dryer dont get hot
Try cleaning all the vents inside the dryer all the way to the outside. Be sure and clean around the blower wheel lots of things get in where the blower is pencils nails everything. They will block the wheel so it can't turn. Also vacuum the lint out of the motor. Lint most likely the problem. Hope this helps.
Nov 22, 2013 | Whirlpool Dryers
Our dryer heats for awhile, then shuts off. If we let it cool down,it will turn back on for awhile., then get hot, then turn off again
Check to make sure vent/air flow is not restricted.
Try to start dryer soon after it stops. If it hums and does not start, motor is cutting out.
If you touch the motor you will find it to be 'very hot' Touch only for 3-4 seconds.
Oct 18, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
Dryer runs but won't heat
As the clothes gently toss about inside the drum, a temperature control thermostatic disk regulates the heat. It is set for 160f for cotton and it mounts on the blower housing. As air is drawn into the drum and out the backside of the dryer the heat is regulated by this control. It sends 120 volts to the gas assembly. Right next to it is a fuse. The duct fuse is set to blow at 250f. Should that control fail to open and allow for heat to build to abnormally high temps. Note: the fuse will kill the heat source only on most dryer, the dryer will however continue to run. Lint and vent blockage can restrict the airflow and make the heat inside build to dangerous levels.The control thermostat powers up the heat for a minute then shuts down for a few minutes, then repeats this all throughout the drying process, the gas does not stay on! That would burn the clothes. If both of those items check ok and the dryer vent and lint has been cleaned, I next take a look at the gas assembly. I check the flame sensor first. If the flame sensor is open the ignitor will not glow. If that turns out to be good I next check the ignitor itself for continuity. If it turns out to be good I replace the coils. Those coils cannot be checked because they do not act up until energised. Sometimes the coils will work, get hot and fail, cool down and work again. I have some repair photos: HERE
Feb 12, 2010 | Whirlpool LGQ9858P Gas Dryer
I have a Whirlpool LGB6000KQ1 Gas Dryer. It
Hello, Unfortunatly your wrong on all 3 counts sorry :) This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safty valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 09, 2009 | Whirlpool LGB6000KQ Gas Dryer
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
My whirlpool gas dryer will not cycle through on Automatic Dry. When I start the dryer it will ignite and heat up, but then after it cools, it will not ignite again and therefore will not cycle. I have...
The burner valve coils (2 in a kit) need replaced . After electricity goes thru them , they will warm up , causing one of them to "open" (short internally). It will not work again till the coil cools back down . Only 2 screws hold the coil bracket on , so , they are not hard to change .Don't have to turn the gas off but do unplug dryer . The burner valve is located in the front of the dryer by removing the front panel .
Jul 23, 2009 | Whirlpool Dryers
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Heat cycle stops/
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
part nos 694540 and 694539
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer shts down during load
Have not solved problem but after messing with it more I think that the hi limit themostat may be the problem. It seems like if I let the dryer cool down then try it again it seems to work fine for awhile. Does this sound like something that may cause it to shut down. The load problem didn't seem to a factor for I reloaded it with the original load weight. I have not replaced part yet going to try few more loads soon.
Jan 26, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
152 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
