Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore elite 42936, when I closed the door and started it nothing happened. I opened the door again and a little plastic piece fell out. Any Ideas?
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
42936- My kenmore elite he front-load washer w/steel tub-has scrapping/unbalanced like sound coming from washer when in spin cycle, then after completed there is shredded plastic/fiberglass like mater
Sound like one of the wights has come off or is loose and damaging the drum and other parts take a under the machine and you may see the problem
Jul 29, 2014 | Kenmore Washing Machines
Kenmore Elite HE5t washer - Door is hard to open and close
It may be sprung in the hinge or there may be a tiny piece of debris causeing the door to hang when being opened or closed.
Jun 03, 2012 | Kenmore Elite HE5t Washer
Hi. The bottom freezer light won't turn on. I checked the bulb by putting it in another appliance an it wordked. What gives?
We have the same issue with the 22.4 Cu Ft Kenmore elite bottom freezer. Has anyone figured out the problem? Very frustrating..We have unplugged the fridge..nothing. checked to make sure it was getting power to the light socket..all good. We accidently left the freezer door open a little. maybe 15 minutes..we looked and the freezer light came on..closed the door and opened it again, the light still came on..got up the next morning and no light again..Sure dont want to spend $75.00 for a sears tech to come look at it...
Oct 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
Won't start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 29, 2009 | Kenmore 64902 Electric Dryer
Dryer Won't Start
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Freezer Door Fell Off
Generally, door hinges have a post on the door part and a hole in the box part.
In fairness to Sears, you caused the problem.  Ice is caused by failure to keep the door closed, open containers with damp product inside and the like.  Forcing the doors will cause them the distort and that's what you did.
You may have to pay a visit to Sears and look at a floor model to see what it looks like.  Take a camera.
Nov 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
HE3t wont start
open the top access panel, 3 screws in top rear.
start washer
push up gently on one of the center black wired connectors that connect to the control unit (in back top of washer)
if it starts to work then the relays on the control circuit board need to be re-soldered . a normal reoccurring issue
its rarely the latch
Mar 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
70 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
