Question about Ovens
Do you think as a housewife, well single mother I have the skill to replace a genuine Creda oven element myself? Therefore saving £s in fees of an electrician.
    President:
  • Ovens Master
  • 1,922 Answers
Heck yes why not(start by removing power to unit,then remove rear cover if it is not a front plug in element and remove 2 wiers connected to the elemene,then there are uasally 1 or 2 1/4" or 5/16" hex head screws in the oven compartment take these out and remove element,(some fiberglass insulation may hang onto it,just push that back into housing) reverse the order and you've got it,most tools are household, the nutdriver you may need to borrow from a friend. you need any more assistance let me know..congrats on being a D.I.Y. and good Luck!!! dan
Posted on Jul 27, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
My c561e creda main oven(fan assited)will not heat up.everything else works
Most likely it is a blown heat element, you could check it if you have a multimeter or continuity tester.
Dec 15, 2010 | Creda Europa E010E Electric Single Oven
Oven won't heat past 200 degrees
Unplug the range.
Remove the oven racks.
Remove the screws on the bake element.
Carefully pull the bake element out.
Remove the wires from the element.
Use a volt meter set for ohms/continuity and touch one meter lead to one element terminal and the other lead to the other element terminal.
No reading is a bad element/
If you get a reading your oven control is bad.
Jul 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Main fan oven in Creda C130E won't heat. Everything else working ok. Suspect the element. Does oven have to be removed from its housing to replace the element?
If you remove the inner rear panl of oven compartment, you will see the element.
If you can see removeable screws, then you can change the element from inside without the need to remove from housing.
If screws cannot be removed from inside, then you will have to remove the oven from housing.
Please leave feedback for my suggested solution.
Thankyou.
Feb 16, 2010 | Creda Ovens
Oven not heating up [fan works] the oven is a belling xou 163 the grill works but the oven does not warm up
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Please rate my solution.
Thankyou.
Feb 11, 2010 | Belling XOU252 Electric Single Oven
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Creda Oven Model ESO 210 broken multifunction selector knob
Same thing happened with my Creda ESO 210. The function selector works find. It just doesn't rotate the piece of plastic that has the funtion symbols on it. I contacted the authorised parts supplier in Canada and was told it would cost $90 for the part. After a long wait, the part arrived and it wasn't the correct piece (they'd ordered the little plastic circle with the function symbols on it instead of the knob thingee that moves it). So, if that cost $90, I dread to think what the broken mechanism would cost. So, I gave up and I simply count the clicks from the off position to use my oven. However, if you really want to follow up on this, you can contact www.creda.co.uk.
Jan 20, 2010 | Creda Europa E010E Electric Single Oven
The heating element failed on my W2451 wall oven. Is it something I can replace myself?
skill level ( easy ) 15 min . open door / remove racks / two screws . pull out slowly . two wires remove and reinstall to new element and reinstall . done . don't you feel better now .. mm
Nov 22, 2009 | Jenn-Air JJW8527C Expressions Collection...
My Creda convection oven does not heat up. The
THIS SOUNDS LIKE THE ELEMENTS HAVE BURNT OUT TO FIX FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE PANEL INSIDE THE OVEN REMOVE ALL SCREWS AND PANEL THEN REMOVE THE ELEMENT FROM ITS PLUG CONNECTION TAKE THE ELEMENT TO A ELECTRIC AND PLUMMERS SUPPLY STORE REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE .
Nov 20, 2009 | Ovens
Is it easy to replace the lower element on a jtp 15 GE oven? While the wife was baking last week, the lowere element burned out. Was wondering if I could replace it myself
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Mar 23, 2009 | GE JTP15 Electric Single Oven
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
