Question about RCA R52WH73 Projection Television
RCA R52WH73 Problem
I just bought this tv last January and now the remote control has magically vanished from my house. Working with no remote I use the power and volume buttons on the tv. The other day when I turned the tv on I noticed the screen was chopping the news anchors heads off. On the remote I now how to formatt the screen to fit the screen, but also to move it up or down to to customize. Is there any way that I can do this on the tv it self without the remote?
    Problem Solver:
  • 10 Answers
Unfortunately the functions you require are only available via the remote. Also a replacement remote isn't cheap averaging about $85-150 each and most of the time RCA only supplies universal replacements that only cover the basic function of the origional.
Posted on Jul 02, 2008
I bought 2008 Subaru tribeca and the DVD remote si not working so i bought a new one from Subaru but it's still not working but the unit is ok any idea?
remote volume control not working Questions & Answers ... > Forum > Tags
I bought a Philips PM3S universal remote contro today, thinking that the TV needed one specifically. After one code try, . ... Volume buttons of Sony Remote control is not working for Akai TV. ... not working for Akai TV ... Radio volume control on 2008 Subaru Tribeca does not ... ... RCA TruFlat 27F520T 27" TV.
Media Center Entertainment for Tribeca -
Nov 23, 2015 | RCA 3-Device Universal Remote with...
I replaced the FL231 fuse on my RCA HD52W66 it works ok now but, my remote is...
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Oct 27, 2009 | RCA R52WH73 Projection Television
Universal Remote Codes Not Working
Probably your RCA remote control does not have a specific code for your Sylvania TV. all universal remote controls do not contain all possible codes. You may have to try a different universal remote control. Follow the specific instructions for programming.
Jul 14, 2017 | Sylvania 6419TC 19" TV
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
We have a large screen RCA model #R52WH73 TV. We bought it new about 2 years ago. Today when I turned it on...the picture looks concave and has shadows. Help?
the ITC222 and ITC222a Convergence option missing repair kit from should solve that issue. The kit also contains the CD with instructions.
Apr 02, 2010 | RCA R52WH73 Projection Television
I need the code for my RCA tv using a philips universal remote sru3007 control
You can get it here:
RCA TV codes:
0704, 0002, 0406, 0007, 0011, 0611, 0811, 0312, 0514, 0720, 0102, 0502, 0601, 0817, 0917, 0835, 0901, 0103, 0803, 0211, 0912, 0114, 0519, 0320, 0420
Nov 01, 2009 | RCA R52WH73 Projection Television
Codes lost for one4all
Feb 14, 2008 | One For All URC-1030 Remote Control
Rca universal remote code
I've lost my code list for my rca universal remote is a rca and my tv is rca can you please help me but i can't change my tv so i can watch my movie on my dvd i don't know how to swicthing over to the input so my dvd can play.
Jan 06, 2008 | Televison & Video
RCA R52WH73 Projection Television Logo
80 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
