Question about Sentry Fireproof Safe
Lost key to sandleford es20 safe typed in code will not open
  • Anonymous Mar 13, 2014
    We have lost the key to the safe and would like to know if there is a way of opening it.
149 then A key
or try 149 and B key
these codes can be turned off tho if i remember in the manual...
if it works open dor... press down red button located inside the thick door kinsid the unit.. it beeps.. type new code and A
test to see if it works.
oh and throw it away
Posted on Mar 30, 2010
2 Suggested Answers
SOURCE: Sandlefored ES20 safe- unable to open safe with key or code
lost key know code cannot open
Posted on Jul 04, 2010
Reset n15115 sandleford safe
i forgot my combination to my 15115 sandleford safe how do i open it
Oct 06, 2012 | Sentry Fireproof Safe
Cant open Sandleford Garrison Safe N15115
I have a new N15115,ES20 electronic safe,it will not accept a change of password.when new password entered it only beeps once ???
Jul 18, 2010 | Check Point Network Adapter
Lost keys to sandleford electronic ES20 N15115 tried to open but batteries are almost flat and just keeps beeping do i have to wait for a replacement key to open Jeff Amos
I have locked my safe I think by entering the wrong code. can you please advise how I can set a new code.... I cannot find the book that came with the safe.... thanks
May 21, 2010 | Computers & Internet
Lost instructions for es20 safe
This document might be of help - you'll have to determine which is your proper setup.
http://www.sentrysafe.com/pdfs/OwnersManuals/IntBarracudal.pdf
Feb 22, 2009 | Sentry Fireproof Safe
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Changing the code on standleford es20 safe
If the problem is that the safe is not accepting your pin code, try first code 159A, or 159B that are default codes to open the safe.
If you have the sentry key, open with key, and there is a red button inside the door to reset the code.
If you have no key and default code does not work, call sandleford number at 03 97750699 they will guide in opening the safe.
Nov 07, 2008 | O2 Xda Atom Exec Smartphone
Sandleford electronic safe es20
have just had the same problems if you had the key there is a red button inside the door to reset the code but obviously no key no red button I have the sandleford number to call 03 97750699 or try the factory pre set 159 A or B see how you go
Aug 20, 2008 | Computers & Internet
Sentry Fireproof Safe Logo
1,291 people viewed this question
Top Sentry Home Security Experts
wickedoneroc
Level 1 Expert
ray012965
Ken Williams
Ken Williams
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
