HP PSC 1350 All-In-One Thermal Printer Logo
Posted on Jul 12, 2009
Can I can scan and then save a document?
Can I scan and then save a document using the HP1350? If so how?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jul 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
447
Points
5
Yaa sure u can scan and save the doc. onnce you started scaning itself saves in a provided location
How do I name and save a scanned document in HP C4480 (Windows)?
Hello, Robert -
I hope I am correct in assuming you have the user's manual for the HP Photosmart C4480. Just in case you do not, this is the link to the web page where you can download and save the manual (PDF format - Adobe Acrobat Reader software needed, free):
https://support.hp.com/us-en/product/hp-photosmart-c4400-all-in-one-printer-series/3655558/model/3655559/manuals
After downloading the PDF document save it (Save As) to your Documents folder and give it a name you can find again easily - maybe: HP Photosmart C4480 Manual.
How to save a PDF file:
- With your computer, open the PDF document in Adobe Acrobat Reader
- Move cursor to upper left corner of page and left click or tap on FILE
- In drop down File menu, move cursor to SAVE AS and left click or tap on it
- In Save As window which opens, move cursor down to CHOOSE A DIFFERENT FOLDER and left click on tap on that "button"
- In window which opens choose DOCUMENTS in the Documents Library
- In File name box near the bottom of the Documents Library pop-up window, enter the name with which you want to save the PDF document, Example: HP Photosmart C4480 Manual
- Left click or tap on the SAVE button
Note: The steps above will be similar to what you will need to do after scanning any document.
The instructions for scanning start in Chapter 10, Page 64 (Image 304 of the PDF format manual).
Open the scanner through your computer. It is easier to save the document later by operating the scan functions through your computer.
With the scan application open on your computer run the scan process. After scanning the document, you will need to save it. First, you will need to determine the format in which you want to save the scanned document: PDF, JPEG (photo image), GIF, etc.
After choosing the format for the scanned document, in the proper file name box, enter the name for the document you wish to save.
Examples:
Correspondence 2018-Feb-18 Brother
Photo Brothers-Family 2018-Feb-18
Deed of Sale 2018-Feb-18 House
Get the idea? I like to give a date to my scanned document names to help identify them better.
Once you have entered the file name, click or tap on the SAVE button.
Note: I always like to open the saved document from the Documents folder to verify it was saved. Plus, my scanner attaches a number at the end of every file name. After closing out the saved document and closing the scanner winder, I go back and Edit the file name, removing the added number (digits) from the saved file name.
The video you will find with this link:
http://esvideo.es/video/watch/ult2ORqN1eGRiLQ=
is for those who use Windows 8 or 10. Even if you use another Windows operating system (I use Windows 7), you can probably figure out what to do. The video goes through the scanning and saving process step-by-step.
Best wishes.
tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
Scan document save as word file
You cannot save a scanned document as a Word document.
You need to save it as a jpg image file first and the use a image to text/word conversion program to make a word document.
http://www.software112.com/search-program/1/convert+jpg+to+word.html
1helpful
3answers
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
How to use a scanner?
What OS do you have? If you have a Windows XP or 2000, download and install the full-featured software and use the HP software to scan.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=306895&
If you have Vista and Win 7, HP doesn't have a full-software driver package. You will be using the drivers built into the OS.
For Vista, you can scan using the Windows Photo Gallery (File, Import from Scanner) or Paint (File, From Scanner or Camera) and with some versions Windows Fax and Scan (New Scan, File, Scan).
If you have Windows 7, Paint and Windows Fax and Scan will let you access the images/documents on the scanner.
In all cases, a good cable and ports will make scanning much less frustrating.
I hope this helps.
(alternatively, you could get third party software for Vista or 7. PaperPort is one example)
2helpful
3answers
Scanned documents too large
When you scan them, save them as a different type of document. Try saving them as a web document. They will reproduce almost as good and will be a lot smaller in size (bytes, not inches).
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Hp1350 wont scan press scan button on/resume light blinks buzzing for a few seconds and nothing else.
Did you try print any document just to make sure that printer is connected properly to the computer. If it is printing than try to scan from computer , i mean there must be a icon in your computer "Hp Director", open that and click on scan document. if that doesnt work, than click on start, got to run and than type "stimon.exe" than hit enter from keyboard. Nothing will happen , just screen will flash for a second, than try to scan. if it doesnt work than you have to unistall and reinstall the software
2helpful
How to scan a document using Canon MX310 to Microsoft Word
you can try it by using the scanner option on the control panel. If you are using windows operating system, go on start menu, select control panel and double click scanners & cameras. Double click the scanner online and start scanning the documents. Save it in the format you want but it is usually default as jpeg.
scanned documents usually saved as .pdf file if you run the scan option directly on the printer. By pressing the SCAN button the printer. So do not use this option if you do not want the documents to be saved as pdf files.
HP1350 Watercolour paper
sir ,
your printer is a psc hp1350 ink jet printer . you can only use the the inkjet paper for your printer. If your paper is 8.5x 11 inkjet compatible you can use that to your printer
yours,
alecz
k24674
Grand Canyon Tech
Grand Canyon Tech
