Question about Acer Aspire 5920 AS5920 Notebook
Laptop won't start
When I turn my acer aspire 5920 on it comes up with a blue screen telling me that if this is the first time i have seen this screen i should restart my computer but before i get the chance to it restarts itself and the same screen comes up again. Please help!
  • Aaron Monello May 11, 2010
    Will it start in safe mode?
I'm using acer aspire 5920 ...it having problem once it is turn on it dont shutdown. i seen in some blog .there said update BIOS .i did it. it displays message automatically shutdown . But my friend...
If you show a Blue Screen, you have more problems then it not being able to turn off/shut down?? I would back out the battery so as to stop power from getting to it, AFTER you have it unplugged..then push battery back into to engage, plug the AC cord back into the PC. turn it back on and IF you still show a BLUE screen, you will need a tech to check it further...GOOD LUCK...
Sep 25, 2011 | Acer Aspire 5920 AS5920 Notebook
Accer aspire 5920 laptop no power
try to remove cables and battery , then press and hold the power button for 8 secs. Reinsert the cables and battery back, then turn it on. If no power, then that propels you to contact Acer for repair because power supply won't work on your laptop..
Jun 16, 2011 | Acer Aspire 5920-6727 Notebook
My acer aspire 5920 boots then goes to a black
The hard disk has died. Replace it and reinstall Windows.
Apr 06, 2010 | Acer Aspire 5920-6335 Laptop
Acer 5920 vista page fault in a non paged a blue warrning page
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. If again that's blue error screen come then remove the RAM, clean it by soft napkin, Fix it back on ram slot & on power button. If nothing changes then format the Operating system & reinstall again.
Thanks & waiting for your feedback
Jan 10, 2010 | Acer Aspire 5920-6574 Notebook
Acer Aspire 5920 won't turn on
check the ram chips havent come loose, i had this problem with an acer aspire 5315 (fixed myself). if that doesn't work, check the lcd cable
Dec 26, 2009 | Acer Aspire 5920-6727 Notebook
My acer laptop 5920 aspire switches on and off
If you have the systems recovery program or the discs, give that a try. Sounds like your start up files may be corrupted
Nov 08, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5920 won't read boot config data on start up
hi friend,
operating system of your laptop has crashed. you have to reinstall operating system. entire data which was stored on desktop, My documents will be lost.
Turn on your laptop and open DVD rom. Insert bootable CD which you might got with laptop. then it will start itself. and follow the instructions given on the screen.
Your friend,
Anil
Sep 21, 2009 | Acer Aspire 5920-6335 Laptop
Acer 5920 laptop wont play blue ray on led hd tv ? tells me i need to download a program but then wont let me do that?
Check the refresh rate of both the vid card in the laptop and of the tv--make sure they match--most older tv's run at a refresh rate of 60htz and blue ray players at 128htz meaning they are incompatible--good luck hope this helps
Sep 13, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 AS5920 Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
