Question about Panasonic CQ-VD7003U Car DVD Player
How to set the EQ to get maximum sound from my speakers
How do i set the EQ to my speakers? So that I may get the best sound from my in car speakers!!! Please I brought all new infinity speakers and the in dash reciever has them sounding like crap!!!
    New Friend:
Hw do we get to the EQUALIZER scott!!! Geeze!
Posted on Dec 03, 2012
  • 3 Answers
Turn up the radio and adjust the eq tell you get the sound you are looking for.
Posted on Feb 07, 2008
I have been using 901 speakers and eq with onkyo tx-8522 av. but now when i turn on tape 2 monitor on, the sound become very weak, even i turn the volume to the max. when i turn off tape 2, the sound come...
Qualifier: I have 901's in a 7.1 setup and have written many posts on Fixya regarding how to do it right.
NEVER USE MAXIMUM VOLUME FOR ANY PURPOSE UNLESS THE RISK OF ACCIDENTAL SPEAKER DESTRUCTION IS A ACCEPTABLE.
ONLY now it does that? "VERY WEAK" as in attentuated somewhat or is it signal leakage, effectively silence? How is the EQ wired in? Check its own Tape Monitor button.
If you DO NOT have a separate amplifier for the 901's the EQ will affect EVERY speaker and we know that is NOT desired.
If the EQ is in a Tape Loop of a modern AVR and you activate the loop two things will happen: 1) the 901's will sound better and the rest of the speakers will be at risk from excessive amplitude at the extremes; 2) any digital source will be disabled.
Jul 10, 2011 | Bose 901 VI Main / Stereo Speaker
Head unit connect
You will only be able to use this EQ on the front or the rear speakers. You will have to get another EQ if you think you need one. Usually, the front speakers of a car's audio system are the smallest and the rears are larger. You really do not want an EQ on the subs. If it was mine, I would hook the EQ between the head unit and the rear speakers. If you feel this does not sound right, you may need, but I doubt it very much, to get another EQ for the front speakers. Good Luck
Aug 18, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
I want to hook my bose 901 VI along with EQ to my Luxman R117 Receiver and also run other speakers from the same receiver. Is this possible?
If you are using the Bose Equalizer to optimize the sound of the 901s by going through either a tape loop or a pre-out/main-in loop, then the only way to do this without also equalizing the sound sent to the second set of speakers is to manufacture a "zone-2" output from the Luxman.
You'd probably need to split the send from the Luxman's pre-out before the EQ and send it to a second power amplifier for the second pair of speakers (if you want the Luxman's volume knob to control both speaker sets) or from a tape level output (if you wanted independent volume controls for the two speaker sets.
The whole EQ thing made 901s difficult to use on vintage equipment with only one "zone" audio outputs. Unless you want to use the Bose EQ on the second set, too, you can't do it satisfactorily without adding another stereo amplifier. But, go ahead and try it, you might find that you actually like the odd EQ that the 901s EQ gives to the second pair!
If it were my decision, I probably would not do it without a second amp, but it's all about what you like, my opinions really don't matter in your house, do they?
Have fun
Jul 24, 2010 | Bose 901 VI Main / Stereo Speaker
Need help on setting custom EQ for my JVC KD R506 in car music system. m not able to find the settings. also any idea how to increase the bass effect from the speakers. can i connect a subwoofer without an...
Set your equalizer to you a V shape or U shape pattern, bass effect can only attain by adding a powered subwoofer, (amplifier and subwoofer). subwoofer without an amplifier doesn't sound good, your system doesn't have enough power to drive your subwoofer.
Jun 23, 2010 | Car Audio & Video
I have a set of 901 IV with no equializer, I am
As far as I know, any equalizer will work. There is a guy on here that might know more about them, but I never had the Bose equalizer and I have Bose speakers for 35 years. The guy at the electronic store back then sold us a little equalizer at first, we graduated from that a long time ago, and now on the 3rd or 4th one. No problem, works great, sounds better than ever. Hope this helps.
May 11, 2010 | Bose 901 VI Main / Stereo Speaker
How should I place the tie mic
Typically you want to wear the mic 6 to 8 inches below your chin clipped to the lapel area. It seems in this case it has more to do with EQ and speaker placement. If you can stand behind the speakers while using the mic. The sound bouncing back and forth between the mic and the speaker is what causes feedback. Also try setting the mic channels EQ with the following settings.
Turn Lows down to about 7 to 9 O'clock
Play with Mids to match actual source, but never boost above 12 O'clock
Keep highs around 10 O'clock (boosting highs increses chances of feedback.) If to muddy sounding keep highs aroun 12 but not over.
Good Luck
Oct 08, 2009 | Audio Players & Recorders
How do you set a 9 band eq for maximum performance
start by all slider in middle position and adjust your 1k and 5k while you are speaking in mic untill you get better sound quality the other slider will be adjusted due to speaker sound type.
Sep 24, 2009 | Audio Technica Audio Players & Recorders
Yamaha HTR-5840 best eq setting to start or use as base line
there are many settings 1.distance (This is the distance between you and the speakers) if your sitting say 6 ft away then you set it to 6 and so on (all front speakers should be lined up the same distance from you) The rear speakers are set up the same way (distance from where you are sitting) then 2. small and large (always pick large for best sounf)3.Tone (this is more a matter of choice) play around a bit with it! the sub should be at least one foot from the wall for best sound! I keep my center chanek a little lower then the other channels for best sound !
Dec 18, 2008 | Yamaha HTR-5840 Receiver
Cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
Does anyone think if the Equalizer presets of iPod sufficient?
Hrm..... This is a tough issue. I have experienced this as well. I can't really solve the problem, I can only share what I have done personally to deal with this. Hope this helps. I have settled on: 1. Leave the iPod's EQ on default and don't change it. 2. Change certain songs that must have EQ help individually. 3. Set the maximum volume setting on the iPod to the highest setting. 4. Assess where and how I listen to music on my iPod and plan to get headphones that work with my listening style. 5. Get better headphones. They don't have to be expensive to produce good sound quality. 6. If you connect it to a speaker dock or a stereo system use it's built in EQ/DSP.
Apr 16, 2007 | Apple iPod MA446LL/A MP3 Player
Panasonic CQ-VD7003U Car DVD Player Logo
153 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
