Question about Sony VAIO VGN-CR220E/P Notebook
All indicators are working fine...but no display on screen...wat shuld i do?
2001 Gmc Yukon tranny issue
With the engine running warm, check the fluid level of the transmission and note the color and smell of it.
If you need further help, reach me via phone at https://www.6ya.com/expert/chris_b82b45c59bcf133d
Dec 07, 2015 | GMC Cars & Trucks
Serial key
if d 000-0000... serial no. and 00000 product key doesnt work den wat shuld i do (3dsmax)
Aug 30, 2013 | Autodesk 3ds Max for PC
My 2007 gsxr 600 braklight keeps burning up the leds and the brake light doesnt work but the running light and turn signals work fine
u need a resistor something to reduce the power ur board in the light shuld have one built in it may have gone leds run on typicaly around 3v ur bike produces between 12 and 14 v its the same as when u fit led indicators u need to restrict that power down
im asumeing the brake light dont work because the leds are dead not because there is no power to them
best advice i can give is u need a in line resistor similar to the ones used on led indicators they take away some of the power and release it as heat energy with the decresed current the leds shuld be almost just as bright and last a lot longer hope this helps
Oct 30, 2012 | Suzuki Motorcycles
My mic is not working wat shuld i do
Check you micro phone.....and make sure it is working properly by recording your voice and then listen it.......is it working Properly?
If not hen repair or replace it with new one.from mobile repairing shop...
Feb 06, 2011 | Samsung SGH-L700 Cell Phone
Transonic tv menu displaying factory in RED.No re...
i can use remote controll for 10seconds den FACTORY appears in red on my screen an den remote does not work wat da??
May 21, 2010 | Televison & Video
My 2003 monte carlo ls has drag to it when switching gears or shuld i say late reaction when swithching gears it takes longer then i think it shuld i dono wats rong
Before guessing at transmission problems, check the fluid level (car warmed up, engine running in Park on level ground) and have the PCM scanned for trouble codes FIRST.
Soft shifting, gradual performance degradation: Poor line pressure rise due to leaking boost valve, clogged EPC filter screen, failing EPC solenoid, or worst case: leaky seals throughout.
Check TPS for smooth and linear electrical response over the entire range of motion. If not, replace. Also replace the boost valve and EPC filter screen and worst, replace the EPC valve when you service the transmission.
Thank you for using fixya and Try not to run or drive the car to hard or further damage could result.
May 10, 2010 | 2003 Chevrolet Monte Carlo
How 2 upload videos
if that .3gp is not working then convert it to .mp4 files that should work
Jul 03, 2008 | Samsung SGH-E900 Cellular Phone
Sony VAIO VGN-CR220E/P Notebook Logo
41 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
