Question about Sony Audio Players & Recorders
Cd drawers on sony CHC-CL1 wont open - Sony Audio Players & Recorders
  • 30 Answers
Possible loading belt, is worn and slipping,will require you open unit to repair,let me know if you need help with disassembly
Posted on Jul 27, 2009
  • Johan Sandgren Oct 23, 2011
    Hello! I have the same problem. Do you know where I can get hold of a new belt?
Cd drawer not opening on sony mxd-d4
Could be bad belts, lack of lubrication on the MD side and even a bad power supply filter capacitor of the larger type. It would need to be seen by a repair Technician to resolve all issues.
Jan 20, 2013 | Sony MXD-D40 MiniDisc Player/Recorder and...
Sony CHC-CL5MD cd player is stuck and the cd's wont open. is there a reset button?
you need to replace loading belt, and possibly you need to grease/lube sliding mechanism also - "But this is the last you will to do" Because it is pain in a***s to do that properly. I recently repairing my CHC-CL5MD and spend two or three days to assamble it back properly. Because if you miss gears positions, you will stuck with it for long. So i recomend for replacing loading belt. You will need a belt with 45 mm in diameter.
Maybe here is someone who has LCD screen for CHC-CL5MD? I screwed up with it when cleaning screen inside from dust. screwed up with LCD flat cable - it is so fragile.
Sep 16, 2010 | Sony Televison & Video
Cd skips at beginning of cds
the data on compact disks usually starts on the outside of the disks and spirals to the center. My guess is that the laser unit that reads the data is malfunctioning. It moves on a rail from the outside of the disk to the center. About all you can do if try to clean the laser unit or lens assembly. If you can get to the laser lens, blow it off with canned air. If you can not get directly inside, open the CD drawer and shoot the canned air into the machine through the drawer openings. I suggest that you open the CD drawer with the open button then unplug the machine. At that point the drawer should be open and you will have some access to blow off the CD reader.
good luck cleaning the CD reader!
Jan 28, 2010 | Sony CDP-CX300 CD Player
Sony chc cl 5 md - cd changer doesn't open
I had a similar problem with my sony cd changer. Took it apart it turned out to be the drive belt a 3 pound part. Got a new slightly smaller one and works well. Very easy to replace.
Jun 24, 2009 | Sony CHC-CL1 CD Shelf System
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
PRESET RADIO STATIONS
Click Sony Support to download user manual of CHC-CL1 to know about setting radio preset function.
Mar 18, 2009 | Sony CHC-CL1 CD Shelf System
Cd player wont respond
Did you fix it? I have the same problem but can't find any solutions.
Dec 11, 2008 | Sony CHC-CL1 CD Shelf System
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
CD problems
hi you push the button and it dosent work? maybe the button went bad push harder pull the button out ( if possible) and push with something small and hard you hear anything after you push? if soo then the drawer is stuck or the engine is about to die (not enough power to open the drwer) take a flat screwdriver and shove it (gently) between the carack of the drwer and try helping the drawer out maybe a plastic wheel will brake from this soo be careful in the end these system are ment to start dying after 5 years soo if this is the case sorry wont do any good have a good one
Mar 26, 2006 | Sony CMT-HPX9 CD Shelf System
332 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
