Question about JVC AV-36D502 36" TV
Interference? Hi, I have a JVC AV-36D502 36" TV. Ever since we brought it home years ago, we noticed that when you rolled it around the room, in certain parts of the room, reddish colored bloches begin to appear on the corners of the screen. This happens with nothing connected to the TV. I've tested this by pluggin only the tv into the wall or power bar and letting the screen turn blue. As I move it around, in some areas of the room I get red spots on the corners of the screen. When there is a cable signal, this translates to discolored corners of the picture (no red but more greenish). The red is only there when the background screen is blue. It has never been a problem before because we had found a spot where in the house to place the TV where this problem wouldn't occur. Now we have moved to a new house and this is really presenting a problem as we can't place the TV where we want it. We originally got a replacement from JVC when we noticed the problem as well as other issues and it happened on both sets. Has anyone seen this? The obvious answer would be interference, but I don't know what else could be interfering.....any help would be much appreciated.
  • 203 Answers
The picture tube on a TV can be magnitized by the Earth's magnetic field. The noise heard when you turn a TV on (usually followed by a static noise on the face on the TV) is called degauss. What this does it remove any magnetic variations on the tube due to things like the magnetic field and speakers. However, changes to the TV in orientation to the Earths magnetic field will cause the tube to have a magnetic bias. This is most prominent when turned 90 degrees. The easy way to clear this is to turn the TV off for a little while and then turn it back on. But remember that any movement once it is on can cause the discolorations to reappear. My suggestion would be to turn the tv after you've moved it to the location you'd like to view it.
Posted on Nov 15, 2007
  • Benjamin Madison
    Benjamin Madison Nov 15, 2007
    That should read "My suggestion would be to turn the TV on after you've moved it to the location you'd like to view it."
Television speaker distortion
hi take it back to where you brought it from i've for a repair or new tv
thanks
regards
shaun
Jan 05, 2014 | Televison & Video
I have a JVC AV-56P575. The problem is while watching the TV I left the room for several minutes and when I returned it was off. I tried the power button and it would not turn on. I unplugged it then...
Tv DM power supply board might have dying parts like capacitors are bulging or puffing up on it tops.U have tools like a soldering iron,a desoldering pump or a roll desoldering braids and can u also do basic soldering too?Yes.Tries websites like Tvrepairworld.com buy a capacitors set kit put together by them.Tries replaced all dying power supply board capacitors.
Mar 22, 2011 | JVC AV-56P575 56" Rear Projection...
Receiving HD from Dishnetwork
Hi. You will love the dish. I have enjoyed it in my home for a number of years. I like the HDMI cable because it is the best quality and simple to install, one cable does it all. If you don't have one yet get it at walmart where it is about half the cost of other retailers. All satellite TV is HD without you doing anything special. So yes, it will do HD from whatever input you choose.
Jun 27, 2009 | JVC AV-65WP55 65" Rear Projection...
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
AV-2053m
My problem is solved!!! I called my neighborhood TV repair shop. The technician suggested I check the Internal Speaker Switch on the back of the TV. And sure enough, I had accidentally move the switch to the OFF position while carrying it from one room to the other. Ahhhhhhhh!!!!!!!!!!!!! my 13 year old JVC is as good as new!!!!!
Aug 02, 2008 | JVC AV-32260 32" TV
Red and Green lines
Yes,it's worth fixing....if done right, with first quality parts.
Should hold up 3-5 years....What can you tell me about
previous parts ??...............................................T.
Jan 28, 2008 | JVC AV-48WP30 48" Rear Projection...
White lines through the picture
they might be going again have you tried auto focus
and adjusting convergence on the menu?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 16, 2008 | JVC AV-48WP74 48" Rear Projection...
65 in JVC with a possible convergence mis-alignment
2 Convergance ic and have to check resisters · http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 20, 2007 | JVC AV-56WP30 56" Rear Projection...
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Nov 22, 2007 | JVC AV-27D303 27" TV
JVC TV Issue
the problem with your tv is in the video circuit the ic or transistor needs to be replaced there is a box on the fixya home page just enter your zip code in the box and it will help you locate a repairman in your area.good luck.
Apr 13, 2007 | JVC AV-32F704 32" TV
JVC AV-36D502 36" TV Logo
213 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
