Question about HP OfficeJet 6210 All-In-One InkJet Printer
Officejet 6210 all in one
When I plug my printer in it makes this continuous beeeeeep noise and will not stop until i unplug it? HELP !!!!
Remove and check color cartridge message
Posted on Dec 06, 2007
The beeper on my HP Officejet 6210 All-in-one unit is on all the time on or off with power button. The only time the beeper stops is when it is unplugged from the wall outlet. I got an auto reply to try to...
I want you to try NVM (Non Volatile Memory) reset for this printer. Perform the printer is connected directly to wall outlet with now Surge protectors.
  1. Remove the ink cartridges.
  2. Disconnect the power cable from back of the printer while its ON.
  3. Press and Hold OK and CANCEL button, while holding the button insert the power cable and continue holding it for 20 seconds
  4. Printer will turn OFF.
  5. Turn ON the printer and insert cartridge when it prompts.
Jan 20, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My HP 6210 all in one printer reports a paper jam but I can't find it or stop the loud noise it makes when it tries to reset. What should I do?
please perform the steps provided below.
1. unplug the power cord
2. reinsert the ink cartridge
3 if the issue persist click on # & 6 and click on okay
Dec 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 will print but with terrible clicking noise
Ok this Sounds Crazy but it worked for me and its easy to try. Unplug the unit and pick it up and turn it side ways and gently shake it. Sometimes a small piece of plastic has broken loose and is interfering with the works and if you can dislodge it from its current location it will stop. Be careful not to hurt youself doing it. Also, I have one printer with a missing tooth on one of the gears and has been growling at me for a long time.
Best of Luck,
Oct 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printer makes non-stop clicking noise when plugged in. Had been printing a document, it stopped halfway through, froze, began clicking and the error light began flashing. Doesn't respond to any of the...
The rollers of the printer must have accumulated dust such as sand or something. Try cleaning with alcohol the parts which moves in time of printing. The curcuit may also be damaged. Thanx.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Officejet 6210 All in one stuck in self test mode
Try unplugging the printer for a minute and then plugging it back in.
Feb 26, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 210 All in one Carriage jam
Nothing you can service on the printer.
try unplugging the power cord and move the cartridges.
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Officejet 6210 noisy rollers
i believed this issue is on the mechanical side of the printer.if the grinding noise is very noisy if you still have the warranty of the printer you can go ahead an ask for the replacement of the printer coz it is an issue with the mechanical part of the printer..
Aug 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 printer
unplug all the cables ang plug them back in
also try reseating the cartridges
May 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Mar 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
231 people viewed this question
Ben Johnson
