How do i turn off smart image off on my philips 242g5dejb
I tried all the button on my screen and on the little thiny thats included in the box. it says i should press the smart image button, but i don't know where it is
In Philips 220CW8FB 22 inch LCD Monitor, go To bottom o your lcd, press first button on your lcd , And hold up approximately 3-4 Seconds. And smart image will turn off .
Dont Buy Philips monitor. I have 20 pcs monitor and after one year half of them had malfunction. smartimage with vertical lines back and forth and that all controls are locked that cant be unlock by holding any button. Some had white screen when Resolution exceed 1024X768 (when 1280X768) after a year.
Maybe they program it to malfunction after a year. My CDR king and AOC monitor had no problem 2yrs to present date. Philips monitor are garbage Sorry for bad english.
You have 3 CRTs inside of your TV that create image. Blue, Green and Red. Looks like one of them need adjustment due aging. Remove front grille. Than remove center "shielding" piece held by 4-5 screws. Behind this cover you will find little black plastic box that have 6 rotating buttons on it. Take you time to study them. There is three columns and two rows. Columns represent color, rows - "Focus" or "Screen". You need to locate "Screen" row of three rotating buttons. They will be marked "B', "G", and "R" for colors accordingly. Turn on TV let it warm up and try to figure out witch color is dominating others on your screen. Then carefully turn rotating adjuster counterclockwise using Philips screwdriver. Try to muscle-remember original position of screwdriver so you can turn it back to it. Eventually you will find the right one, you will see lines dissapear when you reduce voltage and reappear when you turn rotating shaft back. Sometimes more than one have to be adjusted. Try to have all three color to be present and visible but with no over saturating and no horizontal lines. Put cover and grill back - and that's should do it! Regards. Russ.
you need to search your universal remote code for a audiovox code try all of the audiovox codes then once you find the right one, how you will tell is when you turn the tv off and on click menu then unlock the tv
