Electronics - Others Logo
D
DALOVEDCHILD Posted on Aug 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW REMOVE WRITE PROTECTED DRIVE - Electronics - Others
Filip Kunsten
Level 2:
  • Expert 53 Answers
  • Posted on Oct 20, 2015
Filip Kunsten
Expert
Level 2:
Answers
53
Questions
0
Helped
12743
Points
103
There is a utility that is built into windows its called DISKPART
Make sure you select the USB drive not your OS/Data drives
Try this link http://knowledge.seagate.com/articles/en_US/FAQ/005929en?language=en_US
My memory stick is showing write protected, how do i remove it, does not even wamt to format
hi thembi.
Go to My Computer and under Devices with Removable Storage look for your cardreader; right-click on it and click Properties. In the pop-up box, sometimes there's an option to Remove write-protection. Change the status of this option and try again. Remove your memory stick from the drive.
How to Format A Write-protected SD Card/USB Drive/Pen Drive ...
or go to this link and have a read up.
memory stick is showing write protected Google Search
1helpful
Sir my pen drive is no format it is show is write prodected
Download this tool it will help you:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?swItem=MTX-UNITY-I23839
Gmail.comhow to remove file protected from pen drive data traveler and also please send any link to down load the software
Kingston Data Traveler2.0 USB Device 4gb write protected remove cannot remove write protected file from usb plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz send me this solution
email addres- [email protected]
1helpful
USB Flash Drive is write protected - How do I remove it
You can see a small button in your flash drive, then you slide that to remove the write protected.
2answers
Remove Write Protection
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
21helpful
9answers
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
1helpful
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your Pendrive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your pendrive.
19helpful
2answers
How to remove write protect on my usb flash drive
Make sure your mp3 "HOLD" option is not on!
Its really as simple as that. The hold button 'protects' the files.
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
