Loud noise our washer makes a loud noise but goes through all the cycles just fine. the noise is similar to what a baseball card in a bikes spokes would make.
  • 248 Answers
Hard to say for sure without more info. Sounds like something caught in pump though. Give us the brand and a model number.
Posted on Nov 16, 2007
When I go at about 40miles(speed ) it's a loud the gears don't stick but the higher the speed the louder it get's need to kind of know what to tell a mechanic is to where to start to look.I doesn't
I would suspect it is a wheel bearing issue, if it sounds similar to a baseball card in the spokes of a bicycle, stays somewhat same pitch just louder with speed that is where I would look. Does noise go away or change when making turns?
Nov 08, 2011 | Hyundai Motor 2002 Sonata
I have a 95 Dodge neon that started making a noise like a baseball card in a bike spoke yesterday. I know my brakes are good probably at least at 50% and it only happens whan I"m applying the brakes....
does the noise come from the front? could be a warped rotor. when you step on the brakes a warped rotor causes the pads to rattle because its not flat any longer.turning the rotors will fix this. hope this helps
Jan 24, 2011 | 1995 Dodge Neon
My jeep makes a sound from the rear for example today backed out of a parking spot and a loud clicking kinda like if u put a baseball card in the spoke of a bike only louder
Check the back brakes . I believe you have drum brakes in the back.The brake hardware. ie..Springs, clips.. come apart sometimes. And this will cause the clicking noise you hear
Nov 26, 2010 | 1998 Jeep Grand Cherokee
I have a lg washer Model# wm0642h and yesterday my wife was washing clothes and during the last spin cycle it started making a loud clicking noise kind of like when you put a baseball card in the spokes of...
Sound like something has gone in between the drum and the outertank, usually a bra wire.. unless you can see it poking through a hole in the drum the only other access points for retrieval are through the sump hose at base , or the removal of heating element.. other than that it becomes a strip down job... but usually the 2 access points are sufficient..
Dec 19, 2009 | LG WM0642H Front Load
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Drum won't spin freely
Are you sure that there is nothing sticking through the holes in the drum like a nail etc or a screw from trouser pockets, it could be that the heating element has come loose and is scraping against the drum or that the bearings have gone.
Feb 04, 2008 | LG WM-2077C Front Load Washer
Loud noise
There's probably a penny or something in the drain pump. I've had this happen several times and it's easy to fix.
1. Make sure the washer is drained.
2. Remove the plastic panel at the bottom held on with the two plastic screws.
3. Drain the last bit of water into a pan by opening the cap on the black rubber tube.
3. Unscrew the big white cap on the left.
4. Look in there and you will probably find a penny or hairpin, etc.
5. Put everything back together.
I think your manual will probably describe this too.
Jan 09, 2008 | Bosch WFK 2401
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
