Nokia 3110 Cellular Phone Logo
Posted on Jul 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY NOKIA 3110C SECURITY CODE DOESN'T UNLOCK...MY IMEI IS 354161020225035 AND I HAD ENTER THE MASTERCODE GENERATED BY (www.crazy4mobilez.com/mastercode.asp) AND STILL DOESNT UNLOCK THE PHONE..WHAT SHOULD I DO?
  • Tenzin Gyats Sep 07, 2009
    i forget my restore security code so how i can unlock it ?
  • Anonymous Apr 19, 2012
    hello sir this is prasad from hyderbad.i forget my security code,can u plz send me my security code ,imei no is 354161023867387 thank u.
Anonymous
Level 2:
Sniper:
  • Expert 65 Answers
  • Posted on Jul 12, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
65
Questions
Helped
27313
Points
371
Select Menu > Settings > Security settings.
  • To set the phone to ask for your Personal Identification Number ( PIN) code every time the phone is switched on, if this function is supported by your Subscriber Identity Module ( SIM) card, select "PIN code request".
  • To restrict incoming calls to and outgoing calls from your phone, select "Call restrictions".
  • To restrict your outgoing calls to selected phone numbers (if this function is supported by your SIM card), select "Fixed dialing".
  • To specify a group of people whom you can call and who can call you, select "Closed user group".
  • To set the security code for your phone, select "Security level". The preset security code is 12345.
  • To change the security code, PIN code, PIN2 code or restriction password, select "Access codes
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1362
Points
Anonymous
Level 1:
  • Posted on Jul 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1362
Points
I changed my security code of nokia 3110 and after changing i forgot my security code of nokia 3110 now do u hav some solution to unlock my security code and my iem code is352032021429144 n if u some solution then u can message me on [email protected] or [email protected]
Princedb4
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 10, 2009
Princedb4
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3144
Points
14
Go to your phone settings open the security codes then enter 12345 and press ok and select off to deactivate the your code
1helpful
4answers
I forgot my nokia 1112 security code. IMEI is 353648019601540
Based on your IMEI: 353648019601540, this is your Security Mastercode: 1342230530.
If this doesn't work, then the last resort is to have it reset by Nokia.
Hope this helps.
2answers
I fopgot my formating code nokia 3110c
If you forgot your Nokia Phone's Security Code, you can still reset it by using the Master Security Code of your Nokia Phone. Where to get it? You have to know first your phone's IMEI. To get your phone's IMEI, type *#06# on your mobile. Get the IMEI #. Follow this link. http://www.nokialockcode.com/mastercode.php and type the IMEI of your mobile. Click Generate button and the Master Security code of your mobile will be displayed. Enter the Master Security Code instead of Security code on your mobile when asked to Enter the Security Code.
3helpful
2answers
Master reset code for my nokia 3110c
Hi Friend,
Kindly note down the master security code as follows,
5011615732
or check it in the below link
http://mastercode.nokiafree.org/
Kindly and revert back
Regards,
Ayyasam
3answers
Master reset code for nokia 3110c
here is the master code 4722144174
1helpful
4answers
Unlock code
Hi, willimina your IMEI: 354847011991730
mastercode:
764454375x
The mastercode can be entered instead of standard security code.
and
Hi, ice_ice_icey your IMEI: 354847011964364
mastercode:
647723117x
please do not forget to rate this solution if it works.
and Thanks for using FixYa.
7helpful
6answers
Resetting Security Code
357593006548708.........for this phone try resetting the phone or formatting by entring *#7870# for resetting and *#7370# for formatting in any of the case you should have your original number which is 12345 as the new code after resetting of formating but for formtting you would lose every contacts so you are advice to keep a copy of every important dorcument.
for nokia 5300 also try resetting or formatting to restore the usual pin code "12345" and to do this first copy all contacts and information need first even is restting it(which you do not lose any information) ........... to reset enter *#7870# and to formate enter *#7370# please try the first method before proceeding to the second one.
for nokia 3110c please this is your master code   6003104322
May 19, 2008 • Cell Phones
600helpful
33answers
Master reset code for the nokia 3110c
how to format nokia 3110c,plz help me
32helpful
14answers
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
