Washing machines have computers. They are literally designed for no ''DIY.'' Error code would likely mean ''new computer needed.'' Either way, you need a laptop with a factory testing program installed in it That's how these guys work nowadays. The laptop tells them what to do next, and you (and I) can't have one.
SOURCE: code uc and not spin
Most likely a very common clutch malfunction possibly brought on by a leaky Tub Seal.
See if this post will help Clutch Fix
If you have other questions I will try to help.
Rich
SOURCE: i have a samsung 13kg
If the drain hose is pushed too far down the drain pipe, it will have a tendency to to siphon out. Only use 1 or 2 table spoons of detergent as the washer uses very little amounts of water. Read your instruction manual as it says the drain hose has to be higher than a certain height before it goes to the drain.
SOURCE: My Samsung Washing Machine (Diamond Drum model) problem
You probably did not save the mode you want. See the information booklet provided on how to set the mode.
SOURCE: Sir, I would like to
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
