Question about Sony Computers & Internet
Usb device not worked - Sony Computers & Internet
  • Sony Master
  • 3,051 Answers
Hi there have you tried to boot into bios and ensure that your usb devices are all enabled
Posted on Jul 12, 2009
  • Michael Thomas
    Michael Thomas Jul 16, 2009
    Hello there again.
    you can also try going to device manager by going to my computer and right click on my computer and go down to properties and than go to hardware and than go to device manager look for the device that is giving you the problem and than right click on it and click on uninstall and click ok and confirm the removal of the device than click ok the device will now be uninstalled and the computer will find the device again and reinstall the device for you. you will see your device in the taskbar , and it will tell you that your device is installed and is ready to be used. ok?
    i hope that this helps you out
    best regards mike
Samsung r519 usb ic
All USB not working? If not remove USB device re-boot and then re insert USB device. Still does not work check Device Manager look for any errors under the USB list. That said, how old is your Samsung and what are you using in your USB port?
Oct 29, 2012 | Samsung R519-53S Notebook
Error code 10
How to fix the error
"This Device Cannot Start. (Code 10)"
When working with a USB device in Windows XP
If you have plugged in a USB device (usually a mass storage device) into a computer and it won't work, here are some basic troubleshooting steps to resolve the problem.
First, you want to rule out any problems with the device itself. A good way to do this is to plug the USB device into a different computer to see if it works there. If it does not work in a different computer, then the problem is with the device itself. USB devices, although very handy and portable, can fail just like any other device.
However, if the USB device works in another computer system, then the problem lies with the configuration of the computer where the device did not work.
Follow the steps below to troubleshoot this scenario and make your USB device work again.
1) If you are using a USB cable with your device, check the cable to make sure it matches the speed of the device. Use USB 2.0 cables with USB 2.0 devices and USB 1.1 cables with USB 1.1 devices. Swap cables and check the device, if this does not work, proceed to Step 2.
2) Next, open Device Manager and look under the heading for USB Serial Bus Controllers. If there is a device with a yellow exclamation mark next to it such as USB Mass Storage Device. Double-click on the entry and check the Device Status. If the status shows something like
"This device cannot start. (Code 10)"
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in Windows XP is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
A. Click on Start
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
For more information on Troubleshooting USB device problems, visit the Microsoft Support Article on this subject.
Mar 06, 2011 | Computers & Internet
Code 10
First, you want to rule out any problems with the device itself. A good way to do this is to plug the USB device into a different computer to see if it works there. If it does not work in a different computer, then the problem is with the device itself. USB devices, although very handy and portable can fail just like any other device.
However, if the USB device works in another computer sstem, then the problem lies with the configuration of the computer where the device did not work.
Follow the steps below to troubleshoo this scenario and make your USB device work again.
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in windows xp is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
May 26, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Can't see usb mass storage devise in my computer, though inserting it prompt says that device installed and are ready for use
Delete the USB devices in Device Manager and again connect your USB device.Let it rediscover your USB device.
If you dont know how to delete USB device then check following steps.
1) Right Click on 'My Computer' icon on your desktop and select properties.
2) Now select 'Hardware' tab and click on 'Device Manager'
3) You will see the USB device as a mass storage device.Uninstall that device.
Thanks
Feb 27, 2009 | MSI P4MAM2-V Motherboard
Computer won't read my camera memory card...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, you want to rule out any problems with the device itself. A good way to do this is to blame the USB device into a different computer to see if it works there, if it doesn’t work in a different computer and the problem is with the device itself. USB devices, although very handy and portable can fail just like any other device
However, if the USB device works in another computer system than the problem lies with the configuration of the computer where the device did not work
proceed to Step 3.
A. Click on Start
Feb 24, 2009 | Gigabyte GA-8IG Motherboard
Usb ports
  • The driver for the device is faulty. When you plug in a USB device, the computer should load and then configure the device without ever requesting a device driver. If the computer prompts you for a device driver, check the information that came with the device or go to the manufacturer's website to see if a driver is available.
  • The USB port might be defective. If the USB device is connected to a defective port, the device will not work. Try plugging the device into a different port. If all the USB ports are being used, unplug a device that you know works, and then plug the problem device into the port that device was using.
    If the device is plugged into a secondary USB hub with other USB devices, unplug the device from the hub, and then plug the device directly into a port on your computer.
  • Other USB devices might be drawing too much power from the hub. The device you are trying to use might require all the available power or bandwidth that your computer can provide. If other USB devices are connected to the computer and are drawing power from it, the first device might not work. If any other devices are drawing power from the hub, try disconnecting them, and then see if your device works. If this solves the problem, you might want to obtain a USB hub with its own power supply so that you have adequate power for all devices.
  • Oct 23, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
    Usb problem
    If you have plugged in a USB device (usually a mass storage device) into a computer and it doesnt work, here are some basic troubleshooting steps to resolve the problem.
    proceed to Step 3.
    A. Click on Start
    Oct 18, 2008 | Computers & Internet
    CL51-15 USB Port Problem
    I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
    Kevin S.A.
    Sep 26, 2008 | ASI CL51-15 Notebook
    Usb write protect
    If you've updated your software and checked the drivers but the issue still persists, try the following things:
    • Unplug the USB device and then plug it back in. Make sure that the connection is snug and installed in the proper direction. Note that USB plugs fit one way only—if you try to plug them in upside-down, it will not insert.
    If this does not solve your issue-
    • Unplug all USB devices from the computer. Then start plugging in USB devices one at a time, testing each one to make sure they all work before adding the next. Sometimes two devices will conflict and will work together.
    • Is this a new device that never worked, or is it a device that you've had for a while that suddenly stopped working? If it used to work, think about what changed just before the device stopped working. Did you recently add another new device? Install a new program? Try reverting the computer to the way it was before the device stopped working. If it works again, there is an incompatibility with the device and whatever you added.
    • Unplug all but suspected USB devices. Open System Devices menu-
      • Windows: Right click “My Computer” > Properties > Hardware > Device Manager > USB Serial Bus Controllers
      Under the USB information, you should see the USB devices connected to your system. (Disregard any Host controllers) The name may not be identical to your device (it may say “USB Mass storage device”), but it should have the right number of devices listed.
    • If you have the device plugged into a USB hub or into your keyboard, plug it directly into one of the USB ports on the computer. If it works there, the issue is with the device to which it had been previously connected. The device may need more power than the port provides
    • Try a different computer!
    Sep 23, 2008 | Centon Electronics USB 2.0 PCMCIA...
    USB Drive
    Make sure you are matching the compatibility of USB 1.1 and USB 2.0 between the devices (computer and USB devices).
    USB 1.1 device will work in USB 1.1 and USB 2.0, but USB 2.0 devices will not work in USB 1.1 plug in the computer.
    How many USB ports do you have in the computer? Which ones have you tried other pen drives in? List the USB ratings for each device and port in the computer to further help.
    Have the other USB devices been formatted with other computers? The formatting on other systems might not be compatible.
    Nov 21, 2007 | Microsoft Windows Vista Ultimate Edition
    Computers & Internet Logo
    37 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Computer Links
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
