Question about RCA F38310 38" TV
No signal from either antenea A or B
I am unable to get any signal analog or digital on either antenea. I tried my terrestrial antenea and cable. I checked the signal using another TV and the picture is fine.
  • beavermom Nov 15, 2007
    It will not give me a signal from either antenea a or b. I have the cable line hooked up and it won't show a picture or change any channels.
  • gscope Feb 07, 2009
    I have the same problem but I can watch a DVD but A & B antenna says weak signal. I know I have a working Antenna because I have a different TV right beside my RCA F38310. It works fine & its not digital. I alway used a separate Direct TV box,not the one inside the TV and could get local channels with my roof antenna On the A was Directv and B antenna input was over the air. Now it wont. May be in the Directv unit that inside the TV?
    Sergeant:
    Champion:
  • 375 Answers
Enter the setup menu and select auto programed function,
Posted on Apr 08, 2008
I have a Bose lifestyle 50 (from 1999) and just purchased a new Sony Bravia TV. How can I connect the TV to the Bose sound system?
hello!
unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog.
good luck,
Alex.
Feb 01, 2012 | Bose Audio Players & Recorders
No problem, I just want to know if this tv has a digital tuner? It says it has a "digital comb filter". Is that the same thing?
A digital comb filter is not a tuner. It helps improve the appearance of digital content by splitting the luminance (brightness) and chrominance (color) of a digital video signal (DVD, or other set-top box). This filter is only needed when digital content is going to the TV over RF (coax) or composite (analog) inputs. http://electronics.howstuffworks.com/tv-buying-guide18.htm has some details on the filter,
Please provide the model number of the TV for additional information about the tuner. Normally the tuners will be listed as NTSC (analog), ATSC (digital), Clear QAM (unencrypted digital cable) in the US. In other countries you have PAL (analog) or DVB-T (standard definition digital terrestrial) or DVB-C (standard definition digital cable) signals.
I hope this helps.
Apr 15, 2011 | Televison & Video
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
We have a phillips model #32PFL5332D/37 it has a flat screen. Is it digital or analog
Yes this TV should tune to both Digital & Analogue reception. See below I have copied an extract from the Philips technical site which gives you verification that this has digital capability. Hop this is of help to you. Next to analog NTSC broadcast reception, your TV has an integrated High
Definition TV tuner which receives, decodes and displays terrestrial ATSC and
unscrambled cable (QAM) signals.
HDTV quality is only reproduced when a broadcaster or cable provider broadcasts
HDTV signals.
Jul 24, 2009 | Televison & Video
Converter box
3/23/09 --- I don't understand why you would hook your converter box or antenna to your DVD Player. Converter box is only functional between an antenna and a vcr (and/or a TV). DVD Player hooks directly to TV (NOT thru a vcr, coding on dvd discs will screww up the signal and make it fade!) Good luck.
Mar 20, 2009 | Insignia Digital-to-Analog Converter for...
Magnavox DTV converter shows no signal
do you have your converter box hooked up to an antenea? If so, if you move the antenea, then you may have to reprogram the channels through the converter box. This happened to us. So, we played around with the antenea until we found the most channels came through and marked the area around the antenea (you can use tape, or if you do not care a permanet marker like us. Note our antenea sits on top of our tv.) We have not had any trouble since. We marked the place for the antenea, in case someone moves it or so we can try to get more channels when the final switch happens. We gain a lot of stations, but lost only one.
Hope this helps,
The Gordons :)
Jan 06, 2009 | Insignia Digital-to-Analog Converter for...
Send and receive speed
That's not even a coherent response. Even analog phones go from an analog signal from your home, to a digital signal at the carrier, to an analog signal at the recipients end. It all goes digital at some point.
Fax machines work fine with a digital phone. The baud rate may need to be lowered in some cases, but working for a cable company, I've personally worked with hundreds of fax machines that work just fine.
Try lowering the baud rate and/or using a DSL filter if you are having problems. If you are unable to find the baud rate or speed setting on your fax, you may want to contact Canon to find out how.
Dec 09, 2008 | Canon FAXPHONE L80 Laser
Digital Converter Box
Hi William
You TV is able to receive Free to air Terrestrial Analog broadcasts by just connecting the antenna. However if you wish to receive Digital Terrestrial broadcasts (DVB), you need to obtain a digital receiver for Terrestrial Digital Broadcasts. It can be easily connected to your TV.
Nov 11, 2008 | Televison & Video
RCA F38310 38" TV Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
