Question about Dell E173FP 17" LCD Monitor
Dell 19" Flat Screen Monitor
I have a Dell 19" Flat Screen Monitor and I can't get it to move up or down on its stand. Any advise?
Re: Dell 19" Flat Screen Monitor
I have a DELL 2405 FPW. I had trouble the first time finding the button but it was at the very bottom of the stand under the cable channel. I'm pretty sure if it won't move up and down that it's locked in the down position. See if you have a button that will allow it to slide.
Posted on Nov 17, 2007
0 characters
3 Points
How to remove stand from dell monitor + fp1800
First, find a sturdy flat surface. You will be laying the monitor on it's face - face down so get a towel, blanket or something soft to cushion the monitor on the flat surface.
Lay the monitor face down on the whatever cushion you chose.
There are two black machine screws on the back on the plate that is part of the stand. Remove these screws and the stand will slide free.
May 04, 2012 | Dell UltraSharp 1800FP 18.1" LCD Flat...
The picture on my monitor is upside down. the mouse is even running backwards. started after I changed a broken monitor stand.
Hi Sobek,
Go into your Computers Display settings and click the advanced tab.
The settings for rotating your screen will be on there.
Hope this helps!
Please Rate:)
Jan 03, 2011 | Dell E193FP 19" LCD Monitor
In moving to a new apartment I flattened the neck of the circular stand with the monitor LG flatiron slim 19" into the box. Went very easily. Now when I put up my computer the stand of the monitor...
On my HP monitor on the stand, I have a locking mechanism that doesn't allow the display to be raised. I need to press a button on the stand while pushing down the display, then the button is possible to be pressed down. then while holding it down, I can pull the display upwards as much as it comes.
the stand locks in my case when pushed all the way in.
Maybe this is the same thing on yours? Maybe not?
Oct 03, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Hyundai flat screen monitor upside down display help?
There are 4 screws on the back that connect the monitor to the stand. Remove them and turn the monitor right side up and replace the screws tightly. OR you can change your layout in your video card settings.
Nov 20, 2008 | Hyundai L91A 19" LCD Monitor
Broken Stand
ya..tats replaceble..jus ask in the shop where u buy your monitor..
Sep 05, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Position of monitor
There is no mechanism on the stand to raise or lower the monitor.
Aside from removing the stand an setting the monitor on the table leaning against something or machining a shorter stand, there is no way of lowering the e196fp display
May 31, 2008 | Dell E196FP 19" LCD Monitor
Remove stand
we need picture of it, if your not talking about the swivel base.
Dec 02, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
70 people viewed this question
Top Dell Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a Dell Computer Monitor Expert? Answer questions, earn points and help others
