Question about Panasonic Televison & Video
Panasonic Viera Link stop working
I have a TH-42PX80E with SC-PT460 Home Theater system. The Viera link has been working without problems until recently. When I press the ''Viera Link'' button on my remote I get the message ''Function not available''.
I have checked all setup parameters and everything is set according to manual. I use a HDMI cable connected to HDMI 1 on TV. I can see DVD etc. without problems on HDMI 1 connection.
Hey, you're not the only one to have this problem. Please see also
http://www.fixya.com/support/t5668469-viera_link_stopped_working_stating
Hope someone can help us all!
Posted on Jan 25, 2011
  • Mister Smoff Jan 26, 2011
    Well, it turns out there's a simple fix for this! (Ihave the exact same set up as you by the way).
    It's simply a case of the old I.T. solution of "turn it off and then back on again".
    Turn off ALL of your kit, ie the tv AND the AV gear, at the plug socket.
    Leave it off for a few minutes.
    Turn on the AV GEAR FIRST and then the TV.
    All should now work properly, it did on my kit anyway!
    Hope this helps.
  • Melissa May 02, 2018
    How do you turn on the AV GEAR
I need to find firmware update for model sc-bt228. it wont play new blu-ray dvds.
The only firmware update available for the sc-bt228 is here: http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Home-Theater-Systems/Drivers-Downloads/model.SC-BT228.D#ts . It is dated 9/27/2010 and is a Viera Cast Update.
If you do not end up at the right tab, make sure to click the Drivers and Downloads Tab.
I hope this helps.
May 25, 2011 | Panasonic Home Theater System System
I have a 42 inch panasonic viera th-p42g10a. i have dvd connected to av1, foxtel to av2, av3 is vacant. I have lost volume to both dvd and foxtel connections, yet i still have volume when watching normal...
This is a problem with your components. You can have the components replaced with a new set which may be expensive, or live to learn using av3 only with a switch system.
Mar 03, 2011 | Panasonic VIERA TH-42PX80E 42 in. Plasma...
I got a panasonic sapt 460, which is almost 15 months old, hardly used, but the drive is not opening now. it is making some sound when you press the open/close button but doesn't eject the tray. Any ideas?
I am having the exact same problem with mine and mine is about 15 months old and I hardly use it either. All of a sudden it's just started with this error.
Oct 25, 2010 | Panasonic SC-PT460 Theater System
How do I change the regional coding on my Panasonic SC-PT460, I cant play half my library of movies. -Janus-
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to
try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
Oct 12, 2009 | Panasonic SC-PT460 Theater System
Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Sep 10, 2009 | Panasonic Televison & Video
Panasonic sc-pt460 home cinema system not getting
1 of your ics could be blown causing the amp shut down
Jul 15, 2009 | Audio Players & Recorders
How to connect Panasonic TV, DVD Recorder & Home Theater together
missing one connection connect stereo rca jacks behind tv labelled audio out then connect to any available input in home theater receiver i dont think you need the optic cable connected to anything
Jan 27, 2009 | Panasonic Home Theater System System
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
Cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Televison & Video Logo
1,971 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
