Question about Nokia N95 Cellular Phone
When i close the slide my screen goes blank i can receive calls but cant see whose calling
Slide wont slide
My Nokia c2-00 shows "Contacts not ready" message after I turned it on. I can't see received calls, missed calls, dialled calls & contacts list. I can make a dial call, but I can't get receive call. How to solve this problem?
Jul 17, 2013 | Apple iPhone 3G
Nokia N8 problem. When making and receiving calls the screen go blank if in sun or when your hand is in front. when it is ringing and you pick it up its goes blank you cant see who is calling, it only...
You don't have to worry about this, actually there is a sensor in Nokia N8 which senses the heat of your body so that when your ear is touched with your phone during a phone call, the screen is automatically locked so that no button is touched or clicked accidently when your phone is touched with your ear; it is just due to the sensitivity of the touchscreen display.
Jul 22, 2011 | Cell Phones
Can't make phone calls with my touch slide always force close. When I try to make a phone call, the screen goes black and I can't view the dialer. Please help!
The problem with the phone is the flexi ribbon thet slides the phone up and down, it is not properly seated that is why it is losing contact with the main board of the phone, hereby resulting in blank screen while dialing or making a call.
The flexi ribbon is known as the flex, so as soon as you replace the flex of your phone, it will work perfectly fine once again.
Have a repairman fix the flex of your phone, and it will be in good condition once again.
Take care
Oct 13, 2010 | HTC Touch Dual Slider Smartphone
Purchased in sept 2009 and screen went blank in oct 09.they replaced it and now its doing the same thing
can you still receive calls even when the screen is blank?
I don't think the screen is the problem of your phone, but a flex problem. This blank screen issue is a common problem with slide and flip phones.
This occurs as a result of constant opening and close of flip or slide phones which makes the flex to worn out.
The flex is the one that connects the screen to the phone main board, and once this flex is weak/worn out or loose contact, there won't be any display on the screen.
Therefore check the phone flex and not the screen. Screen doesn't just get spoilt, except it hits the ground or something.
Take care.
Mar 19, 2010 | Motorola Mobility Rival A455 Cell Phone
Screen goes white and cant press the C or OK buttons
Yes you have to .The strip inside is a common problem on the samsung sliding phones
Jan 10, 2010 | Samsung SGH-J750 Cell Phone
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
My Nokia N70M goes Blank, LCD is lit, but cant see anything!
u have a display problem ur display needs to be changed
Sep 01, 2009 | Nokia N70 Cellular Phone
My LG KS360's screen goes blank when i slide it open. Also when i receive a call i cant hear the person on the other side. What can be the problem
i have this problem too ,
ive found out though , when someone calls you and you cant hear them you need to click the loudspeaker button and put it down to volume 1 , thats the best i can do sorry , also my screen is still blank if anyone knows how to fix this get back to me ? thanks .
Apr 14, 2009 | Cell Phones
Nokia N95 Cellular Phone Logo
126 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
