Question about Frigidaire 24 in. GLD3450RD Built-in Dishwasher
Er message on panel of Frigidaire GLD3450RD
My Frigidaire keeps flashing a Er message with all other features lighted up also. Unpluging doesn't work. Anyone know the sequence of buttons to press to reset? I realize I need to fine out why its giving an error message to begin with, but if I can't reset it I'll buy a new one. Not from Frigidaire though.
Thanks for your help
  • 1 more comment
  • Anonymous Dec 15, 2007
    Yes, I have the same problem on the same dishwasher. How could we reset ?
  • rhaibeck Jan 03, 2008
    I threw mine away and bought a Whirlpool!!! It was only two years old but nobody would help, not even Frigedare
  • Anonymous Apr 02, 2008
    I have the same problem, it seems I should ask Frigidaire to repair it even if out of waranty.
So should we be making sure they are aware of this and if its a common issue they should be fixing it free of charge....
Posted on Oct 29, 2008
  • 3 Answers
I had the same problem, also the keypad for cycle selection was half working. Turning off the breaker enabled me to reset the controller for a while.
Calling Frigidaire did not help mutch, I should call a repairman and maybe they would pay for half the part. DW is 18 months old.
Finally, the control was completly gone and the breaker trick did not work anymore, so I replaced the controller board myself.
Then it did not work either, but had different apparent symptoms before falling in ER mode.
I was able to program my favorite cycle, then I disconnected the keypad flex.
Works fine now!
I only have 1 cycle, but it works. Will try the old controller to see if I put $160 on a new one for nothing.
Posted on Jul 22, 2008
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Posted on Jan 03, 2008
How do I reset my Frigidaire dishwasher? eR light is flashing
Good Afternoon Sammy, thank you for your inquiry!
Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
Mar 21, 2015 | Frigidaire Dishwashers
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
My frigidaire front load washer will not start. anytime I push a button on the front panel the "LOL" sign flashes. on the front of the washer panel d wash rinse final spin control lights are...
Is the message "LOL" or "LOC"? I suspect the child lock "LOC" has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. This feature prevents someone from accidently starting or changing a cycle selection.
There is a small padlock icon in the middle of lines linking the two buttons that let you toggle the child lock on and off.
There are two Frigidaire washers with the model ATF6000ES (the S is followed by a 0 or a 1). The manuals for both are available here: http://www.frigidaire.com/manuals?model=ATF6000ES . The child lock feature is described in the Operating Instructions. For the ATF6000ES0, the direct link to the appropriate manual is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134604400.pdf . See page 2 under Washer Features.
I hope this helps.
Sep 21, 2011 | Frigidaire ATF6000ES Front Load Washer
Error message "clean S"; flashing
Hi
"Er Clean S" is a common error with Frigidaire which means shorted keypad. The issue is with the touchpad/keypad that should be replaced. However, before replacing the keypad you can unplug it and take it apart completely and use a hair dryer to blow some warm air on the keypad assembly to blow the moisture off. Hope this helps...please post back for further assistance.
Daniel
Jun 18, 2011 | Frigidaire PLD4375RFC Dishwasher
Error codes flashing
Hi, This is mainly due to control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually..
Apr 13, 2010 | Frigidaire PLD4375RFC Dishwasher
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Oct 02, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire 24 in. GLD3450RD Built-in Dishwasher Logo
910 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
