Electrical Supplies Logo
R
Rob Wrigley Posted on Aug 15, 2015
What should i do next to start my Powermate generator 5000.
I have a Powermate PMO 435001, with a Subaru engine. NO spark. I replaced spark plug, cleaned the carburettor, disconnected the low-oil sensor, checked the gap between the coil and magnet. Still nothing.? (The generator has been sitting for a couple years.)
5 Related Answers
Anonymous
  • 169 Answers
  • Posted on Dec 15, 2008
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
4stevetaylor
  • 62 Answers
  • Posted on Apr 07, 2009
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Anonymous
  • 37 Answers
  • Posted on Nov 20, 2009
SOURCE: have a coleman powermate 5000. Won't start. Laid
Cleaning the carb bowl is not enough make sure you pull out the main jet and clean it out real good. If it starts with starting fluid then it is definitely a fuel problem.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 12, 2010
SOURCE: I have a coleman powermate 10hp generator with a
Check you electronic ignition module, replace it.
Anonymous
  • 2702 Answers
  • Posted on Aug 30, 2010
SOURCE: coleman powermate maxa 5000 er
it could have sezed up on you take out the plug and try to turn the motor by hand if it wont turn its sezed up,,,if so all you can do is tip down the plug hole a small brop of red x or two stroke oil and rock the motor back and frow till it frees off,,
if it frees off that is!
3answers
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
What is the Coleman Powermate 5000W Generator spark plug gap
Powermate 435001 w Subaru EX30 spark plug gap is between ..006 - .007 according to manual.
How do i start a powermate 5000
choke it and pull the cord, if it has set for a long time, you may need to pull the spark plug and put a drop or 2 of gas in the cyilinder, reinstall the plug andwire and it should start.
Powermate 5000er 10 hp won't start no fire to the plug
Make sure that the generator is full of oil. It has a low oil level sensor that will ground the spark if the oil is low. If you have filled it to FULL with oil and still have the problem disconnect the low oil level sensor (one wire) and check for spark again. IF you now have spark the oil level sensor has either failed or is dirty. (yes you can clean them with carb cleaner.)
If after doing the above you still have no spark... I need 2 things.
1. the actual model number off of the generator Will start with PM or PMO
2. the engine model number / type / series number off of the engine
Thanks for choosing FixYa,
Kelly
1helpful
I bought a used coleman powermate 5000 generator, I replaced the spark plug and fuel filter, it finally started up,it would only run in the "choke" position it ran about 10 minutes and then shut down, I...
What brand of engine & horsepower is it?Also about how long was it stored or last time it was run? The reason I ask is if it was stored with gas in it & a fuel stabilizer wasn't added to it,your primary jet is plugged in the carburetor(reason it will only run while choked).
2helpful
2answers
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
COLEMAN powermate 5000 generator w/a Subaru engine
Check the vent in the fuel cap to make sure its free to breath. It could be creating a vaccume in there and starveing for fuel. Maybe run it with the gas cap off and see if the problem gos away.
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
