Toshiba Satellite L305-S5907 Laptop Logo
Posted on Jul 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My keyboard is a mess when almost all the keys
I sent my laptop to a get cleaned and they open it to get the dust out and when it came my keyboard is a mess almost all the keys from the keyboard have a different function is there a way to reset the keyboard to its normal?
examples of the keys:
<- (Left arrow) =h
-> (right arrow) = l
w = \w
p = /p
Anonymous
Level 3:
  • Toshiba Master 32,281 Answers
  • Posted on Jul 12, 2009
Anonymous
Toshiba Master
Level 3:
Answers
32281
Questions
Helped
7912689
Points
102259
They may have removed the keys to clean the keyboard and placed them back in the wrong spot.
Check the keys against another beyboard and see if the keys have been placed in the wrong spot.
Take it back to the people/company that did the work and tell then the keyboard is not working properly.
Spilled drink keyboard
ifixit dot com sells the screwdriver you need for the bottom plate (and pics of how to take it apart)
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
tip
How exactly to clean your laptop
Cleaning laptop case Cleaning the exterior portion of the laptop case can help keep the laptop looking new. The exterior case of a laptop can be cleaned by using a damp cotton cloth that has been dampened with water. It is not recommended that the exterior case of the laptop be cleaned with household cleaning solutions. However, if there is a substance on the laptop that cannot be cleaned with water, we suggest using rubbing alcohol.
Cleaning case openings
If dust, dirt, hair, or other substances are in the case openings, it can prevent air from getting into or out of the laptop. This can cause the overall heat of the laptop to increase, and in some cases may also cause such issues as random reboots.
Look for laptop openings where the laptop draws in cool air from outside or blows out any hot air from the inside of the laptop. These openings are usually on one of the sides, the back, or the bottom of the laptop. Dust, dirt, hair, or other substances can almost always be removed easily using a cotton swab and/or compressed air.
Warning: If you're using compressed air to clean the openings that have fans within them, it's possible that the amount of air blown on the fans can cause them to over spin, damaging or destroying the fan. To help prevent this issue, place something in-between the fan blades, such as a toothpick.
Cleaning laptop keyboard
Like almost everything else on a laptop, a keyboard is also different from the standard computer keyboard. With many laptop keyboards the keys cannot be completely removed. Therefore, we suggest cleaning the keyboard by using the same damp cloth you used to clean the exterior case of the laptop. In addition, compressed air can be used to spray any dust, dirt, or hair from in-between the keys.
If you've spilt something onto the laptop keyboard (like a soda) that's causing the keys to stick and cleaning it does not help we suggest that you have the laptop repaired since the keyboard cannot be replaced.
Cleaning laptop mouse (touchpad)
Cleaning the laptop touchpad can help improve the look of the laptop and also many times will help improve the responsiveness of the touchpad. To clean the touchpad surface, use the same damp cloth used to clean the exterior of the laptop.
Cleaning LCD display
Additional information about cleaning LCD and flat panel displays can be found on our main cleaning page.
Cleaning internal laptop components
Cleaning the inside of a laptop computer can be a difficult task. However, in some situations, it may be necessary because of excessive dust and/or dirt buildup within the computer, such as on the processor's heatsink.
Unfortunately, however, because of the complexity often involved in disassembling the laptop to reach many of these areas, Computer Hope cannot provide this information online for every laptop ever made. If you believe after cleaning your computer that it is still overheating because of dust and/or dirt buildup, we suggest taking the laptop to an authorized repair center.
Other cleaning information and help
Additional information and help with cleaning other portions of computers as well as discs and other computer related peripherals can be found on our main cleaning page.
on Feb 01, 2010 • Computers & Internet
In my laptop some keys are not working
Probably that is a result of sticky dust particles under the keys of your keyboard. Get your computer to a computer technician to open it up and blow and clean the dust off. The cleaning should be done using benzene
Some of the keys dont work and CRTL is always press on.
Your Keyboard pad is full of dust or there is someliquid that spilled down the keyboard and the keys are now sticky. This is normally solved by opening up your laptop and have the keyboard pad cleaned entirely. Probably you need to get a computer techincian who is going to help you to strip up the computer and be able to clean the keybord. Make sure you remove the power adpter from the socket and that the laptop battery is removed. Use a smooth cotton cloth with a bit of benzene or methrated spirit when cleaning. Let the keyboard pad dry up for about 20minutes, ten re-connect everything as it was and you should be good.
2answers
How to clean dust under the keys of logitech keyboard?
Here are a few methods:
Find a vacuum cleaner that has a hose thar allows you to insert the hose in the exhaust end of the vacuum cleaner. Then use the air blowing out of the hose to blow the dust out of the keyboard.
If you have access to an air compressor use that to blow the dust out of the keyboard.
Places that sell computer supplies sell cans of compressed air, use this to blow dust out of a keyboard (the most common method).
If the problem is extreme the keys can be VERY CAREFULLY pried off the keyboard using a screwdriver (if you've never done this before you should try it on an old keyboard of no value to you to practice).
Hope this helps.
2answers
My computer is automaticlly turning down the volume and the Quick launch button for turning down the volume is flashing, as if you're pressing it.
it sounds as though the quick launch button is stuck down, have a look around the button to see if there is a build up of anydirt around the button which is causing it to stick, if you can get a pin down the edge of the button you may be able to gently lever it up so it no longer being activated.
Hope this helps
2answers
Other letters on my keyboard doesn't work..
Well could be that the keys that don't work might be dirty try using a compressed can of air and spray the keyboard also turn it upside down and shake might be dust clogging it or you might have to reconnect the keyboard so you might have open it up. Worst case the keys probably crapped out
I have a dell inspiron 1420 laptop. its keyboard is not working. none of its key respond on clicking. it tells me to reseat the keyboard. how to solve the problem? if to reseat, how to do it?
1. check the driver, reinstall & try.
2. check with a external key board. if working fine then ur motherboard is OK.
3. open the keyboard & clean the dust in the keyboard cables and motherboard connector.
4. if still not working ur keyboard might need replacement. check for any liquid spell on keyboard.
5. for replacement contact DELL customer support.
1helpful
Keyboard sticks
Hello...
Looks like you need to clean the keyboard. It maybe a dust or something that's stuck in there, too. Get a clean, dry paintbrush and you clean the key as if to take away the dust (I do it, too). Do not open your laptop unless you know how to do it. Hope this helps... :)
1helpful
The keys of my laptop are getting crazy!
Hi there.
There is a possibility that the keyboard is degrading and may need replacing which is not un-common, or the keys maybe sticking due to hair, biscuit crumbs, dust etc which is lodged under the keys.
The best way to check is to turn the laptop off, turn it on its side with the lid open, get a soft, clean paintbrush and clean the keys gently tapping on the keyboard to knock out the foreign objects.
If you still suffer the same symptoms then it will be the keyboard that needs to be replaced.
If you still have warranty, take advantage of that and send it to be repaired for free.
Good luck and thanks for using FixYa!!
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
