SOURCE: The Picture is filled with rainbow colors
Hello Big Sav,
It sounds like you have a Convergence Correction IC problem. This problem happens quite often and is fixed by replacing the ICs and the biasing resistors. There are many articles on the Internet about how to do this yourself. Here is one:
http://www.digitalhome.ca/forum/showthread.php?p=564268#post564268
I should mention that, If you do not have a background in electronics you could do damage to your TV by performing this procedure. I you feel that you can not perform this procedure properly have a qualified technician perform it or have the board serviced at a TV repair shop that specializes in board repair.
I hope this helps,
Thank you,
Shuttle83
SOURCE: vizio 37" LCD color problem!
is the TV still under warranty. if it is I would call Vizio and request a main board be switch and if it is not under warranty I would call a TV Repair shop and have them put in a Main Board.
SOURCE: distorted picture on RCA LCD TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part # 259638 search the web for the part.
SOURCE: Tv pic has redbluegreen images pic distorted
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs or defective ICs. If you feel that you want to attempt the repair yourself, please update this with that indication and additional details and instructions will follow. The parts for this repair will run about $40-$60.
Dan
