Question about NetGear WGT624 Wireless Router
Cannot connect to xbox 360
My router wil connect to my laptop but no my 360, i need the wire less key number apparently but cannot find anywhere??
  • badlad1uk Nov 17, 2007
    no, it has security, my xbox asks for wpa key and doesnt work from there. it says is connected but then asks for it.
Screw u
Posted on Dec 13, 2007
  • 41 Answers
Is your router being broadcasted so that everyone can see it? I'm not to familiar with xbox's but do they have their own MAC addresses?
Posted on Nov 17, 2007
Xbox 360 sony laptop media center problem
The firewall on your laptop may not work and/or you may need a software update either on the pc or xbox
those are the most common
your set up is ok
Sep 27, 2009 | Microsoft Xbox 360 Console
Xbox live 'internet' connection failing.
This will be why...
you need to wire the xbox to the router.
if you wire it to your laptop then its just a network connection between the laptop and the xbox.
Im not to sure but if you keep the same setup you may be able to share the internet connection.
Apr 06, 2009 | Microsoft Xbox 360™ Premium White Console
Xbox 360 live using internet through my laptop
Normally you would connect your xbox directly to the router. Is there a reason you are trying to connect to your laptop instead? (distance, etc.)
If that is what you truly want to do then first thing make sure you are using a CROSSOVER cable to connect your laptop and xbox together. standard network cables only apply to connecting to routers, switches, and other network controlers. If you are connecting two devices directly you must use this type cable. It is ussally red.
The share tab is only for sharing dialup connections to LAN connections. You are sharinbg two LAN connections so all you need to do is bridge them and make sure there are in the same IP group. Check the status of your wireless card to see what address the router is assigning to it. Then assign the IP to the wired adapter with a differnt higher number.. Example: If your wireless card is 192.168.1.100 then make your wired adapter 192.168.1.151 This should make it work.
Again, it would be much easier to connect your XBOX to the router like it was intended ;)
Jan 03, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
Connecting xbox 360 to laptop for xbox live.
This site has all the info you need to connect your xbox 360 to a laptop and then wirelessly to live :) :
[url=http://howtoconnectwirelesslytoxboxlive.blogspot.com/]How to connect to xbox live wirelessly[/url]
Oct 26, 2008 | Microsoft Xbox 360 Console
Att 2wire wireless and dlink
the only thing you need for connecting 360 to wireless is an Internet connection, an 802.11G wireless router, and a wifi adapter that connects to your 360. They have these at walmart or any gaming store. I suggest giving your 2-Wire back to ATT! NOT QUALITY. Especially for gaming.
I myself prefer my box to be hard wired as lag is far less. BUT..for wifi
Get a Linksys Router and XBox brand wifi adapter for 360. Also google xbox connect. Instead of paying for LIVE
James Mac
Aug 03, 2008 | 2wire (1000-400108-001) Router
Xbox 360
The Xbox 360 does NOT have an "internal" network adapter, you'll have to purchase one separately (I believe they retail for around $99) in order to connect wirelessly.
If you DO NOT purchase the wireless network adapter then you'll be forced to connect with an Ethernet cable.
Jul 18, 2008 | Microsoft Xbox 360 Console
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Problem with streaming from my laptop to my xbox 360 wirelessly
Call microsoft for a solution, they will most likely know in a few minutes. Even though you get punjab from india.
Mar 02, 2008 | Microsoft Wireless Network Adapter Xbox...
NetGear WGT624 Wireless Router Logo
52 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
