Question about Garden
Length of throttle cable
Can not get original part so hope to replace with universal but as i dont have original i cant measure
  • 38 Answers
In general universal replacemant cables have been made to long for any lawn mower.
so you just need to cut that to a suitable working length.
Posted on Jul 12, 2009
What is/are the length/lengths of a throttle cable for a 1997 Honda Recon 250? Thank You
You have an inner cable and outer cable... they BOTH have to be specific lengths,(and they are not the same).. Did yours break?... get pinched?.. Its easier to purchase the original factory cable than try to make one! MANY MANY years ago you could buy all types of cable ends, inner wire, outer sheathing and make your own..now its not $$$ feasible to make your own,, and CHANCE having it break or an end fall off (the wrong end) and end up inside your engine!!..ooppsss.. You will have to get someone who works in a parts dept. to measure a NEW one..inner and outer.
Sep 13, 2018 | Honda 2004 FourTrax Recon ES
What is a good belt size to use to bypass the a.c. pulley in a 2007 Ford Taurus V6 3.0
it will be pretty much hit and miss to get the right bely
you can get an estimate of the belt length by measuring the distance between where the existing belt contacts the power steering and crank pulley
make a note of that length (A)
now using a tape measure measure from the contact point on the crank pulley around the ac pulley to the contact point on the power steering pulley
make a note of that length (B)
now take A from B and reduce the original belt length by that amount
example -- if the original belt is 1485 mm long and the difference is 145 mm then you would be looking at a new belt length of 1340 mm
well that is the general idea
personally replacing the ac compressor is a far better idea , even if you do not re-gas the system or replacing the ac pulley bearing --cheaper still
Jul 08, 2017 | Ford Cars & Trucks
Need to know length of throttle cable for 2007 kawasaki vulcan 900 classic with 18 in ape hangers
Either measure it with a tape measure or measure the standard bars then the height difference with you apes and add that to the standard cable length
Feb 23, 2015 | kawasaki Motorcycles
Sanyo instruction manuals
Most universal remotes don't have all the functions of the original remote controls.You may be out of luck unless you can find an original remote. There are web sites that sell original remotes. Just Google TV parts stores.
Sep 07, 2014 | Televison & Video
Throttle Cable - Idle Cable
Measure the distance between both ends of the cable. This does not include the ends (Ball or round ends) on each of the cables to get the measured length of the cable..
Mar 19, 2014 | Motorcycles
Throttle cable
If you're not changing bar, just measure the length of the outer cable housing and get the same size.
The cable is held into the housing by a small spring clip that fits into a groove on the cable's ferrule.
With a small screwdriver, pick out the clip, and pull the cable out of the housing.
Mar 02, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Clutch,brake and throttle cable lengths to install 16" handle bars on a 95 heritage
The only true way to get the proper length cables is to go ahead and change the bars. Then, use stiff wire to "mock up" the cables. Once you do this, measure the wire to get the length you need. Then , go to this website and see what you need. If you need custom cables, you can order them here.
http://www.barnettclutches.com/products/custom_measuring_guide.aspx
Good Luck
Steve
Feb 16, 2011 | Harley Davidson FLSTC Heritage Softail...
Need Remote code
Unfortunately, there are no codes available for that particular brand of TV. Don't bother with a universal remote because you'll have the same problem. The manufacturer of that TV didn't communicate with any universal or cable remote manufacturer which is why it can only be controlled by the original remote or a replacement from the manufacturer of the TV.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 04, 2009 | Durabrand DWT1905 TV
Cant read wirring diagram
as long as the steering lock no longer works you can leave the original switch where it is and mount your new switch in a convenient place. unplug the cables from under the steering column and extend them to your new switch. you should only have 4 cables there to go on your new switch. the battery cable is the one that is live all the time, a thick cable, the ignition is the one that makes the ignition lights come on when the key is turned, a thick cable, the accessory cable is the one that becomes live when turned to 1st position on key, a thinner cable, the starter cable is the one that goes to the starter motor when key turned to start a thick cable. hope this helps
Apr 23, 2009 | 1986 Ford Ranger 2WD
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
