Question about Nokia 6300 Cellular Phone
Display shows local mode - Nokia 6300 Cellular Phone
Derbi gpr display mode
Hi, Anders for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Derbi Gpr 125 4T Digital Screen Modes
Derbi GPR 125 4T 4V 2011 Engine and LCD problem
https://scootergrisen.dk/scooterhjemmeside/download/derbi_gp1_servicemanual.pdf
https://www.oemmotorparts.com/oem2.asp?M=Derbi
http://www.derbi.com/fr/images/stories/modelos/37/manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 30, 2012 | 2010 Derbi GPR 50 2T
How to turn off beepiing and alarm on sportline 240
To set/Disable Hourly Chime/Alarm
Step#1.Press "Mode" (center button) until you are at "Time Display" (the home screen)
Step#2. Hold "Split/Reset" Button it will show the alarm time
Step#3. Keep holding Split/reset button and press the "Mode" (center button) "Hourly Chime Is On" when dashes appear above display (in alarm mode) "Hourly Chime is Off" When no dashes appear!!!!!!!!!!
Jan 24, 2010 | Sportline Stopwatch
I cant turn on my nokia 1600 bec.local mode always show on the screen.how can i solce this problem?
"local mode" display will come only if there is a break in the centre pin of the battery or if you  have connected the service cable.  check which one is actually the problem
Jul 02, 2009 | Nokia 1100
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
Nokia 1600 displaying local mode
didn't you try another battery?
Oct 16, 2008 | Nokia 6120
161 fatal error C7300
Try this - WARNING - will reset everything to factory defaults
The machine must be put back into "Shipping Mode" in order for the consumable counters to reset.
In order to place the printer back in "Shipping Mode" do the following:
0.27c?openelement&fieldelemformat=gif
1. For the C72/74/92/94 models, hold the (1) and (5) keys down, for the C73/75/93/95 hold (0), (1), (6), and (7), while turning the printer power on. (Hold until "MAINTENANCE MODE" is displayed)
2. Press (0) five times until "ENGINE DIAG MODE XX.XX" is displayed.
3. Press the (2) and (4) keys simutaneously, "ENGINE DIAG LEVEL 3" should now be displayed.
4. Press the (5) key once, "LOCAL PARAMETER SET" should now appear on the display.
5. Press the (6) key three times until "FACTORY WORKING MODE" is displayed.
6. Once "FACTORY WORKING MODE" is displayed, press (3) once so "Shipping Mode" (Fuse Cut Enabled) is displayed in the bottom line.
7. Next press and hold (3) & (7) together, until "Shipping Mode" stops flashing.
8. Power the printer off and back on, now the printer will reset the consumable counters. ecblank.gif ecblank.gif ecblank.gif
Aug 30, 2008 | OKI C5300n Led Printer
this problem is because of water which is dried over some components inside ur phone. take it to technician, it need to be cleaned from inside with acetone, if problem still stays then it need to be repaired very minor.thanks.
Feb 24, 2008 | Nokia 6030 Cellular Phone
just remove the battery and short the battery polls (+, - ).
Dec 03, 2007 | Nokia 1600 Cellular Phone
Nokia 6300 Cellular Phone Logo
766 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
270rexton
270rexton
