Question about Canon ZR830 Mini DV Digital Camcorder
Recording When i try to use the recording on my camcorder, the screen just stays black with a dim light in the back, but when i playback previous videos and pictures, it will show.  How can i get the camcorder to show and recorder new things?
Re: Recording
There is a recall on some Canon camcorders. Call Canon technical support. They will fix for free as well as free shipping. I had the same problem.
Posted on Nov 17, 2007
0 characters
3 Points
No camera image on screen while recording on sony DCR-DVD7 sound is recorded, playback from previous recordings are fine
If it is a white screen and you have been recording in bright daylight you may have the Night Plus slider on.
Jul 04, 2010 | Sony Handycam DCR-DVD7 DVD Camcorder
Jvc gr-dx28ek black screen during recording
if u can see the old videos in playback mode those videos when ur camera was ok then it is
see the link for free repairs from JVC dont worry if u are out of warranty and not on list just call them PLS RATE ME FIXYA for help
Apr 14, 2009 | JVC GR-DX28E Mini DV Digital Camcorder
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
Nov 25, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
May 04, 2008 | Sony Handycam DCR-TRV460E Digital...
No playback
Can you see what is being recorded while recording on the screen?
Apr 16, 2008 | Panasonic NV-GS17 Mini DV Digital...
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Sony handycam
you told that you are getting previously recorded one that means the screen is safe.and there will a button to change the screen for recording to thr right side of the cam or at the back of the cam try it and see.if still your are not getting it then recording part is damaged.
Aug 20, 2007 | Sony Handycam DCR-DVD100 DVD Camcorder
Canon ZR830 Mini DV Digital Camcorder Logo
119 people viewed this question
Top Canon Video Cameras Experts
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
